Results 31 to 45 of 47
Thread: xA Series engine Variants
    Nov 2011
    EU
    Default Re: xA Series engine Variants
    Twincharged Ae82 4agzte
    KM = PS :-)
    Engine model and generation: 4agze from AE101 levin gt-z (so smallport. last gen)
    Top End Modifications: standard
    Bottom end modifications: standard
    Forced induction: Yes, SC12 supercharger + TD05 turbvocharger from evo X (TD05H-152G6-12T), 1,2b, supercharger turnes off before 6k rpm
    Management: EMU SA
    Fuel used: Pb 98, Pb 100
    Intake: Custom intake manifold
    Exhaust: 2,5"
    Driveline: E58 LSD transmission
    Feb 2013
    RM
    Carbed, N/A, nothing really too fancy in the build.
    Spec list:
    - Wiseco high compression pistons
    - Stock rods with ARP bolts
    - HKS 272 cams, stock valvetrain
    - Stock crank
    - Midly ported bigport head
    - Weber DCOE 45
    - "TRD-like" exhaust manifold
    Bigport GZE (OEM Rebuild)
    Turbosmart PB BOV
    Turbosmart Boost Controller
    Adaptronic Select 440
    7MGTE injectors
    AE101 CAS
    Bosch Coils
    NA inlet manifold
    Garrett 2560r
    Just Jap A2A cooler
    NitroDann Log manifold
    NitroDann 3.0 Dump/Exhaust
    http://i.imgur.com/2D0VBKh.png
    4agze Bigport 8.0:1 (OEM Rebuild)
    Bosch coilpacks
    440cc injectors
    Adaptronic 440 Select
    Just Jap a2a intercooler
    gt2560r
    NitroDann log manifold
    NitroDann 3.0" Dump and Exhaust
    Jan 2013
    Netherlands
    POWER: 89 Wheel Kw
    CAR: Toyota Celica ST (1998)
    ENGINE: 4AGE 20V Blacktop
    BOTTOM END: Stock
    TOP END: polished exhaust chambers
    EXHAUST: Stock 1.5" downpipe
    Stock 2.5" Catalytic convertor
    Stock 1.7" centre exhaust section
    Stock 1.5" rear exhaust section
    INTAKE: Ramair open air intake
    NOTES: Engine did only 2700 km after the complete rebuild
    Sep 2012
    Arizona
    Engine:
    Aw11 4agze
    Top end:
    Stock rebuilt top
    Bottom end:
    Stock rebuilt bottom
    Forced induction:
    Sc14 supercharger from a toyota previa
    Mangement:
    Stock ecu from an automatic usdm, areomotive fuel pressure riser
    Fuel used:
    Qt gas station 91 octane.
    Intake:
    Custom intake piping, Throttle body from a camry v6, wta setup from a celica st165, n/a big port intake modified inlet port to center facing tvis plate removed.
    Exhaust:
    Stock exhaust manifold to stock resrictive exhaust piping on the car.
    Drivetrain:
    AE95 corolla all-trac wagon. Automatic transmission.
    Check out my ae95 4agze sc14 build. http://www.alltracwagon.net/forum/m-1347147405/ or check out the ride info at http://www.toymods.org.au/forums/for...agze-sc14.html
    KE20XX Grease Monkey charade_16v's Avatar
    Jul 2007
    Car:
    Ke20 Corolla
    4agze bigport (AW11) unopened
    Performance:
    182.9kW/315.8Nm @ 10psi - 13.3@105mph best so far
    Tuned by Silverwater Automotive (SAS)
    Nil
    Nil
    Forced induction:
    Garrett GT3076r
    Management:
    Megasquirt MS3-Pro
    Intake:
    Standard 4a RWD manifold
    Exhaust:
    6boost Manifold, 3" turbo-back, wastegate plumbed-back, 200ci cat, 1x resonator, 1x muffler
    Driveline:
    Custom NPC Clutch, W58 supra box with short shifter, Hilux LSD Diff
  8. #38
    Jul 2007
    Car: AW11
    Engine model and generation: 4A-GE 20v Silvertop. Stock unopened motor
    Forced induction: No
    Management: Adaptronic 440 Select
    Fuel used: 98 octane
    Intake: T3 75mm trumpets
    Exhaust: Standard
    Driveline: C52
  9. #39
    Mar 2012
    5psi from SC14 at idle, 25psi from GT2860RS at 3500+
    Est 300-350hp at engine (Never Dynoed)
    AE92 4AGZE - Smallport
    Cometic Gasket, ARP studs
    Standard
    Management:
    Razorbackecu
    Fuel used
    98 octane
    Intake:
    Open
    Exhaust:
    2.5in with cat and muffler
    Driveline:
    W55
    NPC clutch
    Stock T Diff
  10. #40
    Mar 2012
    Dead stock small port 4AGE
    Factory AE86 exhaust manifold
    Razorback ecu
    111hp at wheels.
  11. #41
    Mar 2012
    277HP @ 23psi (98) with GT2860RS, 310hp @ 18psi (E85) with GT2871
    No power under 5000
    AE92 4AGE
    280' Cams
    Spool rods, Arias Pistons (0.5mm over)
    Balanced
    Custom intake with XF falcon TB
    450x300x75 cooler iwth 2.5in pipes
    550cc injectors with 60psi base fuel pressure
    Razorback ECU and Daewoo coilpack
    Bosch 044 pump
    Cast ebay manifold
    2.5in mandrel exhaust with cat and muffer.
  12. #42
    Mar 2012
    290hp @ 22psi
    AE101 4AGZE
    Mild head porting
    264' cams
    Cometic gasket, ARP studs
    Wiseco pistons on eagle rods
    Unknown 500hp turbo on cast manifold
    550cc injectors and high fuel pressure
    W55 box
    T diff (locked)
  13. #43
    Mar 2012
    134hp with cracked piston (died on dyno)
    AE92 4AGZE
    Stock cept SC14 with XF TB and Nevo 175cm pulley
    15psi
    TRD copy extractors
    2.5in exhaust with cat and muffler
  14. #44
    Mar 2012
    193hp
    Stock AE92 4AGZE with Rotrex supercharger, 18psi peak (at 6200)
    Razorback ECU with Daewoo coilpack
    In kit car (with T50 and T diff)
  15. #45
    oregon
    Quote Originally Posted by samkaos View Post
    290hp @ 22psi
    AE101 4AGZE
    Mild head porting
    264' cams
    W55 box
    T diff (locked)
    Which Eagle rod? Last I checked Eagle didn't make 4AGE rods........
  1. Toyota R Engine History
    Last Post: 02-12-2011, 09:41 PM
  2. MA70 --> JZA70 Conversion
  3. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 12:51 PM
