Results 16 to 30 of 47
Thread: xA Series engine Variants
    got 71? Grease Monkey cooter's Avatar
    wa
    Default Re: xA Series engine Variants
    my last readout 124rwhp
    Current mods
    blacktop 20v 4age
    rsr 4:1 mandrel bent tuned length extractors
    15mm itb trumpets
    water pump impellor blades removed, davies craig ewp 80 no temostat
    2 1/4 cat back underdiff single muffler exhaust
    microtech lt-10s with x4 ignition box, 4 bosch coil packs
    i was thinking that figure might be a lil low for my setup. because a stock blacktop makes what 165hp? 20% drivetrain reduction gives you 132rwhp? even if the stock figures are a bit over exagerated its still not entirely stock. just a thought.
    anyone care to comment? plz lol
    craig
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
    wa
    soz. please remove this post
    craig
    Corolla Feind
    Junior Member Backyard Mechanic jono's Avatar
    Jun 2008
    Motor:
    "100kw" 4age
    ECU:
    haltech e6x, GZE CAS
    Gearbox:
    t50
    Diff:
    ke55 BW68 4.33:1 (yeah, yeah)
    Turbo:
    hks 2540
    Intercooler:
    180x65x550mm
    Exhaust:
    steampipe manifold, ceramic coated
    2.5" mandrel, high flow cat, resonator, straight through muffler - so nice and quiet.
    previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUXE
    current:-> 06 BF XR6T, MY13 ISUZU D-MAX 4X4
    Feb 2007
    Timaru
    Engine model and generation: 7A block AE111 BT 20V Head
    Top End Modifications: Sandard cams, standard valves, slight portwork
    Bottom end modifications: 7A Block with Argo Rods, AE101 GZE pistons and rings
    Forced induction: Yes, GT30 type turbo
    Management: Link LEM G3 ECU
    Fuel used Avgas
    Intake: Custom Intake Plenium with BT Quads
    Exhaust: 3"
    Driveline: W57 with Hilux Diff
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Jan 2007
    Somerset (UK)
    AE92 4AGE
    Smallport Head
    Ports tidyed up & flowed
    skimmed head
    Cams:
    Richard Macer cams
    Bored to 1597cc
    Wasner forged pistons
    Standard - 42mm Big Ends
    Decked Block
    Fueling
    Twin 45 DHLA
    Management:
    OMEX ignition system
    Fuel used
    Shell V-Power + Millers CVL @ 1 bottle/20 litres
    Intake:
    ITG Foam Filters
    Exhaust:
    Tony Law 4-2-1, mandrel bends
    2" straight through system with 1 bullet silencer and 1 box
    Other details:
    Dry sumped - supplier Pace
    Fidanza flywheel
    Fidanza Cam pulleys
    4 paddle clutch with Ford Competition cover
    Vehicle:
    Peugeot 306 RWD - www.306rwd.co.uk
    Use:
    Forest Rally.
    Due to misunderstanding with dyno tester the engine was only tested to 8000rpm not 8500rpm that I have it limited to. BHP was still slightly on the way up at 8000rpm
    4AGE in a RWD Peugeot 306 Rally Car
    www.306rwd.co.uk
    Junior Member Grease Monkey FATMR2's Avatar
    Car:
    aw11
    bigport 4agze (changed to 4agte)
    267 cams, adjustable cam gears, heavy duty valve springs, arp bolt throughout, custom port work.
    balanced bottom end, arp bolts throughout
    Forced induction:
    custom made s15 bb turbo with 440hp core
    Management:
    autronic sm2
    Intake:
    Custom made 3ltr alloy plenum/sr20 t/b
    Exhaust:
    3 Inch mandrel bent exhaust with Cat, high flow muffler
    Driveline:
    3 puck Brass Button
    e51 lsd
    Other Info
    pwr water to air i/c
    rx7 injectors 440cc
    Funnily enough not a whole lot was done to the motor to achieve this.
    Junior Member Grease Monkey KE25 RACER's Avatar
    May 2006
    Car:
    Ke20 Corolla Race Car
    4age Silvertop 20v
    Cams, Headworks and alot of secrets!!
    balanced bottom end
    Forced induction:
    NIL
    Management:
    Motec M4
    Intake:
    Quad Throttle Bdy
    Exhaust:
    Custom Ceramic Coated Headers into 2.5 inch stainless muffler running through car, dunping infront of back wheel
    Driveline:
    Ceramic Disc clutch, W58 supra box with sohort shifter, Sprinter GT JDM Disc Brake 4.3:1 solid centre
    If it aint FAST it aint FUN
    perth
    ae92 gze turned 4AGTE
    bigport ported,match ported and cc'd chambers
    camtech stage 2 cams
    fidanza cam gears (dialed in)
    deburred ae101gze block
    spool conrods
    toyo pistons 8.9:1
    lightened crank
    arp bolts/studs
    trd .8 headgasket
    Forced induction:
    ITS turbo 19psi
    Management:
    haltech e6x
    cdi ignition
    haltech coils
    halleffect
    rx7 550cc injectors
    Fuel used
    Ultimate 98
    Intake:
    K&N
    Exhaust:
    3 Inch mandrel bent 1 muffler straight threw and high flow cat
    more to come
    oregon
    full build info - http://www.toymods.net//forums/showthread.php?t=35553
    Short and sweet
    AE92 smallport head - ported
    Web 577 camshafts, T3 timing pulleys set to 111 degrees
    AE92 high comp block w squiters plugged, decked, stock head gasket
    Euro TVIS pistons(10 to 1)
    final measure compression ratio of 10.75 to 1
    AE86 "small" crank w 40mm rod journals, lightened, shotpeened, and balanced "3 rib bluetop type"
    AE86 small connecting rods - lightened, shotpeened and balanced
    wrist pins are aftermarket steel 64 grams vs 89 grams for stock
    blacktop flywheel w AE92 clutch
    crank pulley is OEM 2 row, machined and rebalanced as a single row
    KBD 4/2/1 header
    Brave 60mm exhaust
    FJO racing management
    sequential injection
    wasted spark ignition
    running on 92 octane fuel
    http://i79.photobucket.com/albums/j1...ous1stdyno.jpg
    This is her first dyno run. The initial map was only written to 7500 rpm(engine and cams are good to 8500)
    141whp @ 7468, 108#s wheel torque @ 6127rpm.
    Engine numbers(back calculated by their dyno) 164hp @7468, 128ft/# 6127rpm
    edited - 2nd dyno run now posted. System is still not final tuned, final tuning will take place after the engine has 1000 miles. Please note, there is over 90#/ft for more than 4500 rpm
    ..... and ALL emissions complaint!!!
    Last edited by oldeskewltoy; 22-12-2011 at 04:11 AM. Reason: added link for 1st dyno
    perth
    spool conrods
    toyo pistons 8.9:1
    lightened crank
    arp bolts/studs
    trd .8 headgasket
    Forced induction:
    ITS turbo 21psi
    Management:
    haltech e6x
    cdi ignition
    haltech coils
    halleffect
    rx7 550cc injectors
    Fuel used
    Ultimate 98
    Intake:
    K&N, standard big port manifold modded for rwd with 72mm t/b.
    Exhaust:
    3 Inch mandrel bent 1 muffler straight threw.
    w58, 4.11:1, 16" / 45 profile tyre.
    hitting a wall at 6400rpm, thinking of swapping the turbo as ive never really liked this turbo and i think it could be my gremlin.
    more to come
    May 2010
    south australia
    7Psi
    AE92 4AGE - Smallport
    TODA cam gears
    TODA camshafts (not sure what size)
    Kelway turbo manifold
    Standed
    Management:
    Adaptronic
    Fuel used
    98 octane
    Intake:
    Open
    Exhaust:
    3 inch straight through
    Driveline:
    T50
    Lightend flywheel
    R31 diff
    Other Info
    Quite happy for such low pressure.
    Sep 2009
    Rear Wheel kW
    Estimated Flywheel HP :
    Engine model and generation: '99 AE111 Blacktop
    Top End Modifications: none
    Bottom end modifications: none
    Forced induction: none
    Management: stock
    Fuel used 98 RON
    Intake: Stock AW11 (MR2) intake & filter, ducted to blacktop airbox
    Exhaust: Ceramic coated Blacktop manifold; ceramic coated 2 1/4" system to high-flow metallic cat; 7" x 25" dynomax muffler
    Driveline: AE111 six-speed box converted to RWD for MR2
    notes - baseline run after install. The dip at 6500 seems to be the ECU pulling timing (knock ?) - will post again after tuning.
    Also the tacho was not set quite right - the graphs actually stop at 8300 RPM (fuel cut)
    Sep 2011
    136.4hp/101kw
    Engine model and generation: 4AGZE
    Top End Modifications: bosch waste spark igniters, ngk plugs, custom leads
    Forced induction: SC12 @ 10psi
    Management: Wolf 3d v3
    Fuel used 95 RON
    Intake: Stock AE92 4AGE airbox with brand new ryco insert, end of the airbox opened up + stock top mount
    Exhaust: Genie Extractors onto 2.5" Mandril steel exhaust.
    Extra Info: before igniters where changed, car was putting out 117.5hp at fronts
    Jul 2007
    AW11 4A-GZE. Unopened motor. Cusco 164mm pulley (10-11psi), HKS air filter, catback exhaust.
    Same unopened engine as above. 440cc injectors, n/a manifold, KKR430 turbo @ 17psi. Tial MVS-38 wastegate. Straight pipe w/screamer. HKS air filter
    MUAHAHAHAHA
    Oct 2009
    Wellington, New Zealand
    358kw at 32psi
    4agze block
    0.5mm over sized pistons
    Blacktop 4age head
    Custom turbo manifold with Tial 38mm wastegate
    Masterpowers T58 turbo (500hp)
    Sard 800cc injectors
    500hp Walbro intank pump
    Custom Intake with velocity stacks
    Tial 50mm BOV
    3inch dump pipe and 3inch exhaust right through
    Probably missed a few things but you get the general idea
    Matt
    ae100 4agte 96 Corolla wagon 358kw at 32.5psi
    tt132 corona wagon - 2jzgte project
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 12:51 PM
