Results 1 to 8 of 8
Thread: 4age very low idle on a hot day???
    Default 4age very low idle on a hot day???
    hey
    On the hot days we have recently in syd when im driving my my 4age rolla fwd i hit a red lights i slow down of course when i do the revs drop quick.
    when i stop they drop to about 400 rpm there bouts and that drop nearly stalls the motor then it just sits near 500ish rpm on a hot day but on a cool day it runs fine between 800rpm and 900rpm i dont want to forget about the problem so im asking for help on this
    is it an intake thing due to humidity in air as i have a stainless mesh pod filter the only mod i have
    cheers mike
    Default Re: 4age very low idle on a hot day???
    if you have aircon, do you use it on hot days?
    thermo fans can drop your idle quite a bit, mine does, but my idle is all over the place anyway, due to not having any idle bypasses at all.
    Junior Member Grease Monkey toyoda's Avatar
    this seems 2 be very common. on hot days or after giving my rears a good work out my rpm will do the same...
    i have a thermo fan so it might be that like shinybluesteel said.
    jay was asking about this the aother day. jay n e answer?
    i do have air con but cant use it due to missing parts near radiator think its the a condenser and pipe work.
    im not sure whether the termo is running a the time but if its hot i suppose it would be running
    I dont like the term Grease Monkey beige_bandit's Avatar
    A.C.T
    my 4age does the same but i have no A/C and no thermo fan!
    My theory is:
    Air is less dense when its hot or humid, so your idle is set when air
    is at an average temp(hopefully in this case) , then you get out there on a hot day
    and idle drops cause of the less dense air?
    just a thought, but on these hot past few weeks my idle has been changing
    from morning to afternoon.
    Im just a little lost but ill be fine!
    Your idle drops because on all 4age's they have coolant running through the throttle which in turn heats a wax pellet making it softer which then is used to raises or lowers your idle. Its toyota's way of making a cold start. On really cold days your engine will start at 2000rpm because the wax pellet is solid and lower down after it softens it up. Its just in summer the extra heat causes the idle to go lower than the 900rpm standard.
    i am a Backyard Mechanic WiLo's Avatar
    is your pod in any sort of enclosure? if not it may be sucking the hot air from under the bonnet
    A.C.T
    Quote Originally Posted by Goolz
    Umm , 4age's actually have a cold start injector on the plenumb
    And he is talking about hot days not when the engine gets hot
    Last Post: 17-06-2008, 08:53 PM
  2. Low idle??
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 09-01-2006, 12:22 PM
  3. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
  4. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 03:08 AM
