Page 2 of 9 FirstFirst 1234 ... LastLast
Results 16 to 30 of 123
Thread: 2TG Rebuild
    someone say 2t-ze? Automotive Encyclopaedia gerald1's Avatar
    South Australia - ADL
    Default Re: 2TG Rebuild
    nice work terry,
    will be good to see the 22 out n about when its finished. hopefully mine will be "done" soon. well it will need to be cos shes going in the bay to birdwood :-D perhaps i should get on with it.....
    keep up the good work
    cya
    gerald
    ta22 Green with cream vinyl roof, 2t/3t hybrid with a few go fast bits on + 5 speed.
    your rebuild is coming up nicely! well done!.
    The 88260 head looks the goods with the painter cam cover. keep the pics comming. I too have started on my build.
    fonz
    deepdishfactory
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Thanks guys
    I have managed to find these:
    Translated by Google...
    2TG 2.0Liter
    Bore diameter 88.5φ 89φ
    Pin diameter x pin length 22mm x 60mm
    Pin height 35mm
    Ring B sun/size 1.5mm x 1.5mm x 4.0mm
    Connecting rod/crank type Genuine /3TG
    Compression/head type NA/convex +10mm
    Remark 2.0Liter
    63,000 Yen (about $700 inclusive of shipping)
    What do you think?
    yeah i saw those a while back, they look nice. I'd prefer the high comp version though.
    fonz
    deepdishfactory
    Less cheese than a Grease Monkey andurils_sheath's Avatar
    What comp would you say theyd give?? 700 is quite cheap for 89mm pistons for the 2tg
    Quote Originally Posted by Zapp Brannigan
    In the game of chess, you can never let your opponent see your pieces.
    10.5:1 maybe? my 1750cc ones are some where around there. If you deck the block and head, it might get up higher =)
    deepdishfactory
    Which high comp version is that? These look to be pretty high as it is...
    well i've only seen 2 types of high compression pistons for these motors:
    my 2T-G's 1750cc high compression:
    and theres 13.8:1 HIGH COMPRESSION!!!!!
    deepdishfactory
    my question is, how do you manage a 2litre 2tg?
    I met one of guys from the Canberra Celica group that has a 2L 2T-G, he says it drivable, but might need a new o-ring for the upper timing chain tensioner (rag with elastic band fix is quite common these days).
    deepdishfactory
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    I've seen the head in the flesh, and it looks damn good with the red cover and the brass nuts.
    Nice work Terry, those pistons look pretty good, and 10.5:1 would be plenty of comp for a mild street engine.
    You get 2L from a 2TG with an 89mm bore and the stroke from a 3T crank. There is plenty of extra metal that can be cut out of a 2T block.
    gee's i didnt think there was that much metal there!?
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Get those 13.8:1's and those .400" lift cams you wuss
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  2. 2tg and 3tc bearings interchangable
    By styler in forum Tech and Conversions
    Last Post: 18-05-2007, 07:49 AM
  3. 2TG head onto 3TC block...need help
    By quikestsilva in forum Tech and Conversions
    Last Post: 15-05-2007, 08:07 PM
  4. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
