Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 104
Thread: 1J Gurus - spark plug advice
  1. #61
    Default Re: 1J Gurus - spark plug advice
    i dont like the look of the coils being extrenally mounted, it takes away from the stock look.
    and thats saying something, as that single turbo conversion looks factory!!!
    Elmo.
    Haha, there's not much stock about a JZ in an AE71 corolla panelvan anyway
    ReQuieM: it may have been you I bought it from, that would be around the right time. Strangely enough its never had so much as a whiff of crankcase byproducts in it, my 1J appears to have almost no blow-by. Either that or the filter/baffle arrangement under the cam covers is super effective.
    Phil
  2. #62
    veeeery nice, where did the bracket for the coil packs come from? how much did the coilpacks cost?
    as for the blow by, the baffles in the cam covers are very good but my motor also throws 0 oil, infact the only thing that comes out of my cam covers is fuel vapour. i removed my catch can because of this. im now looking at getting a air pump.
    JZA70|R / 12.45 @ 111 mph.
  3. #63
    Just did the heatshrink trick last night, quick and easy job to do Good tip!
    244rwkw / 328hp @ 18psi
  4. #64
    You do get oil from the cam covers, but it takes a long time to build up. They are no LS1 that's for sure. After a couple of years, I did have a bit of a build up in the intercooler that was enough to effect the cooling capibilities of my setup in attempting to make 300rwkw. After I completely cleaned out the intercooler, made another 12rwkw.
    Toyota Corolla Conquest 2003 black manual 1ZZ-FE - Daily
    Toyota Soarer GT-TL 1991 white auto 1JZ-GTE - [email protected] 1.587 60'
    My JZZ30 SOARER
  5. #65
    Quote Originally Posted by JZA70 R
    Bracket is just painted mild steel made in my shed Don't let the swiss-cheese style race holes deceive you, it is just a clever disguise for the DIY project haha
    Coils retail for 70 bucks, but you can get them cheaper through trade contacts. Even Microtech sell them for $100 per pair which is a fair bit cheaper than REPCO, Autopro, AutoOne etc.
    Jampac: interesting point about cooling efficiency, I will keep the catch can after all.
  6. #66
    Anyone used the BCP7R resistored plugs? Or are all the BCP plugs resistored?
    Couldnt find a set of BKR7s anywhere today, so I need an alternative
  7. #67
    don't know what you mean by resistored? I use BCPR7e's gapped to .7mm. I "think" Jampac does as well. Worked well for me so far but I haven't pulled them to have a look since racing yet. No knock on dyno, no hard to start so appear like good heat range for me. Also, apparently the BCPR's are recommended of the BKR's for nitrous use.
    QUICKEST 1JZ'S IN OZ
  8. #68
    Quote Originally Posted by chris davey
    What the??? ...whats the deal with running weird spark plugs? ...dammit if i was at work i could look up the NGK book to see what eack letter meant.
  9. #69
    BCP= 14mm thread, 16mm hex, Projected insulator nose
    BK= 14mm thread, 16mm hex, ISO Projected insulator nose
    R= Resistor type
    E= 19mm thread reach
    S= copper core centre electrode
    so the BCPR7E and BKR7E are both resistor type plugs.
    Phil
  10. #70
    I'm pretty sure can't use resistor type, it'll blow the coilpack or ignitor.
    My JZZ30 SOARER
  11. #71
    2JEJ Grease Monkey petespipes's Avatar
    I'm thinking oil buildup in the intercooler would be from the turbo as there always seems to be a little oil just downstream of the compressor but none on the air feed side.
    [email protected]
    its ok not to know everything
  12. #72
    Quote Originally Posted by jampac
    ummm... I think you'll find the opposite, resistor plugs are usually required on cars running engine management computers because the purpose of the resistor design is to reduce electrical "noise" in the system, in the same way that RFI suppressed ignition leads are required. Unsupressed leads or non-resistor plugs should only be used on the most basic old-school carby systems with no electronics to be interfered with
  13. #73
    so does using heatshrink on the coilpacks effect refitment of the rubber boots?
  14. #74
    Nah they still fit fine. A bit tighter though. Let the heatshrink cool and harden before refitting the boots, otherwise the boots will push the heatshrink back.
  15. #75
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    Not as neat as the other one, but here was my soloution.
    drilled 6 holes in the top middle of the stock cover, and fed the leads through one at a time.
    BUT. It is a complete pain in the ass to change leads, sprak plugs are easy, but leads...
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
  1. Wasted Sparks VS Sequential Spark
    Last Post: 07-01-2018, 11:19 PM
  2. Oil in spark plug chamber 3sfe
    By dundee230966 in forum Tech and Conversions
    Last Post: 09-04-2007, 11:46 PM
  3. 4AGE Spark Plug Cover
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 29-10-2006, 05:13 PM
  4. Spark Plug Question
    Last Post: 22-05-2006, 07:09 PM
