Results 16 to 21 of 21
Thread: Full Boost Squealing Noise - Can't find cause.
    victoria
    Default Re: Full Boost Squealing Noise - Can't find cause.
    sure its not your girlfriend? mine makes all sort of interesting noises when i hit boost
    Junior Member Chief Engine Builder Classique71's Avatar
    pity you have boost leak , and the tendancy to spike early!
    Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4
    "Mongrel Garage - back on Aussie soil! "
    Junior Member Grease Monkey Adrian's Avatar
    Apr 2007
    W.A
    hahahahha lol,
    Yeah spray some "start ya bastard" or "aero start" or something smiler any ware after the air flow meter to check for leaks, the idle will raise if there is a leak
    Forum Sponsor Conversion King
    check that the inlet many bolts are all tight.
    one of my customers had this prob turned out to be loose bolts and the gasket was causing the whistle as well as the high idle.
    the WD40 test works best spray it everywhere it could be leaking on the mani and the idle should come down.
    btw check that there is a one way valve between the idle motor and plenum.
    I had trouble with mine leaking around the injectors.
    How often do those ISCV 1-way valves go bad?
    244rwkw / 328hp @ 18psi
  1. Info: Emissions and Noise Testing
    By infotechplus in forum Tech and Conversions
    Last Post: 09-04-2007, 11:33 AM
  2. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 08:32 AM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  4. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
