well i just put one on a 18r piece of piss really all u had to do was take out the studs on the intake manifold (where the stocko carb went) and bolt the adapter plate where the studs go then bolt the carby on the adapter plate put the throttle linkages on and put a bit of fuel down the primary butterfly and it should start also try to dodge up the vacuum lines (or block)
cheers and good luck
luke
