http://www.delta-digital.com.au/
DELTAMAX is a fully programmable ignition controller in a compact, rugged and affordable package. It is designed to perform reliably in such harsh conditions as the engine bay of a car, simplifying installation: there is no need to penetrate firewalls for new wiring looms.
DELTAMAX operates best with Hall effect and inductive distributors. With these types, the input signal is processed internally by on-board circuitry and the main high-current transistor is also internal, i.e. no external module is required. The unit is re-programmable using the software and programming cable provided. It may be removed from one engine and re-installed on another engine of a different type.
DELTAMAX includes a rev limiter which may be set in 50 rpm steps up to 12750 rpm.
DELTAMAX may be used to replace hard-to-get ignition controllers for imported vehicles such as Fiat, Lancia, Alfa and others. It may also be used in conjunction with an upgraded distributor to replace the entire ignition system in vehicles such as Ferrari and Lamborghini.
DELTAMAX has provision for two ignition maps with simple switching between maps. This feature may be used for competition when different fuels (such as avgas) are used; and in dual-fuel applications where substantial gains in performance can be made by providing the ideal maps for both petrol and LPG without any need for compromise.
