Hey man, there is a lot of info in these site already, just have to do a search....but ill make it easy for you....If you wanna go 5 stud, get a G series diff out of a RN25/27 hilux with MA70 rear discs, and then you can either try to find MS65 hubs (good luck) that will change it to 5 stud (5/114.3 stud pattern same as rear) Or if you want a upgrade of the brakes as well, just go to hopperstoppers.com.au and they can upgrade the front disc and calipers to Ford AU3 in any stud pattern you want...actually they also do a conversion kit for the RN25/27 diff from drum to disc if you want the same all round....
Anyways hope this helped, if not just do a search as there are quite a few brake upgrades you can look at doing....
Scott
