Results 16 to 16 of 16
Thread: How to achieve a desired compression ratio?
    Negative Reputation Domestic Engineer Howieau's Avatar
    Default Re: How to achieve a desired compression ratio?
    Ok its time to order my pistons, Ive completely changed my mind on the whole comp ratio setup and am going to go for something between 8.0:1 and 8.4:1. I found these puppies that I might get but before I do I need to figure out the math;
    http://www.pistons-online.com/sport....a&st=43&end=43
    Based on your post info oldcorollas, this is what Ive come up with, tell me if Im wrong.
    Swept volume with 86mm stroke and 87mm bore = 511cc
    Stock 0.8 headgasket at 87mm was 4.75cc (so to find what the capacity of a 1.42mm head gasket thats mentioned was used on that website, I did 4.75 / 0.8, then multiplied the answer by 1.42) = 8.43125cc
    Combustion chamber = 49cc in head (which I read is for stock gen2 3sgtes) + 13cc (stated on website for piston dish) = 62cc
    511 + 62 + 8.43 / ( 62 + 8.43 ) = 581.43 / 70.43
    Equals 8.26:1 which would be ideal.
    Now that im not going with 9:1 it doesnt have to be so accurate, just as long as it lies between 8:1 and 8.4:1. Please let me know if I've done this right. Many thanks!
    "There is a better way to do it, find it" -Thomas Edison
  1. Compression ratio of hybrid JZ engines.
    By 2JZR31 in forum Tech and Conversions
    Last Post: 21-06-2008, 04:51 PM
  2. 3SGTE Engine rebuild; What compression ratio to go with.
    By Howieau in forum Tech and Conversions
    Last Post: 13-05-2007, 10:48 AM
  3. Selecting a compression ratio for a 20V
    Last Post: 05-07-2006, 10:09 PM
  4. Rod to Stroke ratio
    By tricky in forum Tech and Conversions
    Last Post: 29-05-2006, 08:19 PM
