Originally Posted by Ribfeast
Monroe are just fine had double action from Monaro series on the GT Corona for decades running rally roads.
Struts on my 280zx are Konis but I hear Pedder are pretty good.
The way you make it go round corners is more than just shockers its camber castor, tyre size, wheel size, wheel weight, toe in/toe out, tyre type, horsepower, wheel alignment and rear wheel settings camber castor. Also spring rebound rate, progressive, Stiffness and unsprung weight (lighter wheels better) steering geometry..tyre pressures.etc.
Also well set up anti sway bars
Spring rates, and centre of mass.
You should be able to point a well set up car with the accelerator, watch the world rally cars..
My Corona GT in full Rally trim, REPCO Around Australia 12000 km in 1979.
we spent $$$ and it was able to maintain really high cruising speeds over thousands of KM of dirt as the forward control car,
with never one crash.
We either drove it too slow on roads like this or it was well set up. what do you think??
TAKE A LOOK AT THE TRD SETUP OF THE REAR END.
Normal Toyota
TRD GT2000
Ask the racing teams (they won't tell you a thing). 2c.
But one of the secrets is the stanadium wheels from Italy worth about $500 each in 1976 and weighing less than 16 ounces.
Low unsprung weight less rebound on potholes better traction and contact with the road surface at all speeds.
