You are right. The "floats" aren't "shagged". I was just describing the general area of the problem. I am grossly amatuerish at these thingsIt was actually the needle and seat as well as the pin that holds the float in place. There is no tag on them but there is a somewhat serial number stamped on the flange closest to the manifold. It reads: 4FG7 and the last number/letter is not readable. Other markings on them are AUD where the fuel goes into the float bowl and S.U. CARBURETTORS, BURMINGHAM, ENGLAND on top of the float bowls. They are the slant type and the float bowls are level.
Now that I have had the car running again for a few days I have come across 2 more issues. The first is, I cant get it to idle low enough without stalling. I have followed some of the tuning manuals from various websites and they all use prety much the same method to tune idle and mixture but I still cant get it to idle low enough without it cutting out at some stage.
The second issue which has earthed today is the backfiring of the carbs. I initially put this down to timing and check and adjusted that but it still happens. Then I remember when I topped the dashpots up with oil, it did the same thing, and I thought I had filled them up too much. Revved it for a bit, backfired for a few minutes then came good. So I'm guessing(as I usually do) that perhaps I have the wrong type of oil in there? Possibly too thick? as the pistons are fairly solid to push up with my finger. Could this be the backfiring
and idle issue??
