Results 1 to 10 of 10
Thread: Flywheels and Bolts
    Lincolnshire
    Default Flywheels and Bolts
    Has anyone fitted an aftermarket flywheel before?
    I've had a bit of hassle with mine and the upshot of it is that I have the wrong bolts to fit my flywheel..... however, I still have the old bolts, because it was previously fitted with a drive plate for a torque converter.
    My question is, how safe would I be re-using my old flywheel bolts? If I can get the ones I returned to Mr T back (I gave them back yesterday evening) tomorrow, then I'll use them. But if I can't, then I may be a bit schtuck. Opinions please
    Default Re: Flywheels and Bolts
    It will be fine so long as there the right length. and did originally come from the fly wheel. You dont want to go putting in quarter panel bolts into the flywheel ....
    Yeah it should be fine as long as they're the right ones, make sure you torque them up to the right specs
    This is usually a highly debatable topic on here whether to reuse or not though, do a search and you should find some interesting reading on the subject
    I am the sun
    NZJDM'er Grease Monkey GTI-TRD's Avatar
    I've read many times before, most people saying not to re-use flywheel bolts ever! personally havent had experience with this topic though.
    I was trying to find a link to a Paradise Racing US Ebay auction explaining their point of view for replacing them, but couldn't sorry.
    formerly GTI-TRD now coming at you with 4WD turbo power!
    NZJDM coming soon - pm your JDM requirements
    no problems re-using flywheel bolts, always use locktight on them tho.
    we do clutches and re-use the bolts, also the clutch specialist next door re-uses the bolts, most of the time also,
    30DET... The only way. Carport Converter Kyosho's Avatar
    The bolts will set you back around $5 from Toyota most likely.
    And if you're doing an auto to manual conversion, you need the manual flywheel bolts anyway( Generally, auto bolts are shorter)
    Quote Originally Posted by majic79
    Flywheel bolts can be reused but as stated if you are changing from a drive plate to a flywheel your old bolts won't be suitable as the length is wrong. Most bolt shops will be able to provide the correct hi tensile bolts if you tell them what you are doing. One thing you do not want is the flywheel coming loose, the damage is enormous and expensive.
    Regards
    Greg
    71 ta22 2tgeu,ke35 18rg, ke 35 3k auto,74 ta22 2tg,73 ta22 2t,80 ra40 18rgeu,92 kawasaki gtr1000,95 nj pajero, 2011 jeep patriot,2011 aricat jd495,1979 leyland motorhome (350chev),1995 Mitsubishi Delica
    Too many cars so little time
    Not to mention dangerous!
    I am the sun
    A flywheel WILL come through the trans tunnel if it comes off...
    Quote Originally Posted by Kyosho
    I have seen one go through a trans tunnel and out the roof leaving big hole on the way. Driver spent 3 months in hospital with many, many operations to fix his leg.
  1. What flywheels fit inside a rwd 4a bellhousing
    By goldta22 in forum Tech and Conversions
    Last Post: 14-12-2006, 10:22 PM
  2. 3s flywheels
    By StuC in forum Tech and Conversions
    Last Post: 01-05-2006, 07:25 PM
  3. Flywheels for turbos
    By willwal98 in forum Tech and Conversions
    Last Post: 30-04-2006, 10:15 AM
  4. Flywheel Bolts 1JZ-GTE R154
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-12-2005, 07:05 PM
