Here are some modern terms used in the trade, to my understanding:
Basic service: Change engine oil and filter. Check all fluid levels, brake pads. Check tyres and pressures. Check CV boots. List faults and report for further work. Fill up washer bottle. New oil sticker.
Major service: All of the above plus new fuel filter, air filter, change brake fluid and coolant. Maybe replace timing belt, or whatever the book says to do.
Tune up:
replace spark plugs, fuel filter, air filter. Check plug leads. Spray some wynns stuff of your choice down the thottle at the customers expence (may work, never know). Check ignition timing.
"Give the engine a bit of a freshen up"
This is a slang term, not written in any book. Generaly means pull the engine fully apart. Hone the cylinders, plane the head. Fit new rings and bearings but keep the old pistons.
Full rebuild:
This term surgests the engine will be as good as a new one once done. More likely to involve a rebore and new pistons. New everything. Maybe even pollish the crank. Full valve regrind.
