Hasn't Cliff Hansen done a 92.5mm bore blowing in 21 pounds?
Don't try it on a turbo engine though!
Norbie!
www.norbie.net
(\__/)
(")_(")
i think cliff got the capacity with some clever selection of crank, rods and pistons?
update:
i was wrong - Fast Fours article, date/year unknown:
-16R Rods
-22RE dished (92.5mm) (resulting in 6.8:1 comp ratio)
-eccentric ground 18R crank to add 3.5mm stroke
total engine capacity lifted to 2.4 litres.
note: he is running a very efficient W2A intercooler and boost is a maximum of 21psi.
Last edited by thechuckster; 27-02-2006 at 01:00 AM. Reason: edited for accuracy and spelingk
YUKKY!!!! How the hell could you drive something with such low compression??
...... butt scratcher?!
keep it on boost![]()
The boobs are back
i'd prefer something with some compression thanks.... EWW!!
My 18R-GTE will end up around the 8-9:1 compression ratio, much better![]()
Besides, what difference is it going to make if you take an extra half a millimetre out of the bore? There is well enough there to have a 93mm bore with a turbo.
I really do wonder how the hell he ground the crank to gain 3.5mm of stroke
If he had done it the conventional way of just offset grinding the crank he would have had to use +.320" bearings and ground the crank .180" below its original size.
I guess 16R rods have a smaller big end.
they dont, cause u r supposed to use 16R rods with 22r crank
16/18/20/21/22R big end bearings are all the same
The boobs are back
Its a mystery then. Unless its a custom billet crank. which would have cost 5 g's. Or dramatically resized the 16r rods.
Or the magazine article was completely wrong. It certainly wouldn't be the first time.
Norbie!
www.norbie.net
Originally Posted by Norbie
dont be silly, that never happens![]()
The boobs are back
cliffs car DOES use the 22r/16r combo
The boobs are back
Is there a way i can contact Cliff? Regarding RA28 matters. Please PM if so.
Yeah, show up to a Toyota Car Club of Qld meeting.![]()
Norbie!
www.norbie.net
