Page 84 of 392 FirstFirst ... 3474828384858694134184 ... LastLast
Results 1,246 to 1,260 of 5875
  1. #1246
    nothing stamped on there so i presume these are 8.7's
  2. #1247
    They are not 9.7s as they are stamped on the top, a stated earlier, so they must be the lower comp ones, 18rgu? 18rgeu?
    They look very rusty in the ring grooves. I see a full rebuild happening here.
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
  3. #1248
    wierd it has/had a 230 head on it must of had a interesting life
    and yes im slowley saving money for the rebuild but i got it cheap as chips
    so you really do get what you pay for
    +rep all round
  4. #1249
    Yeah, unfortunately they dont look like 9.7's
    I took some pics for you to compare. This is comparing my 9.7's with my 8.somethings.
    Apart from the dome and the stamping, I can't see any other obvious differences
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  5. #1250
    oh, what orientation is the engine number. They way the old dizzy hole has been blocked up, makes me think this is a bitsa engine made from an 18RC block.
    Current rides...
    2) White RA25ST
  6. #1251
    Quote Originally Posted by timbosaurus
    im pretty sure its a 18rg block its got the upsidedown engine number
    cheers for the piston pics +rep
  7. #1252
    All the 18rg blocks i've had have got the plug in the dizzy hole. The way I could tell is that the dip stick had been move to the other side.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  8. #1253
    Have a look inside the piston skirt.
    88251 = 8.7:1
    88270 = 8.3:1
    Either way, that's and 18R-C/18RGEU rod, so I'd be guessing 8.3:1 or a rod swap has been done.
    (\__/)
    (")_(")
  9. #1254
    That dizzy plug looks right... dont forget it has the oil pump drive gear in it... its not just a block off plate. Steve, I didnt know the 18R-GUE had the same rods as the 18R-C... interesting
  10. #1255
    Oh, that dizzy cover is factory? very homemade lookin'
    Steve, ur right. The 9.7's above have 88252 and the 8.x's have 88251. They must be 8.7's.
    Current rides...
    2) White RA25ST
  11. #1256
    Junior Member Domestic Engineer tricky's Avatar
    Yeah, it looks less stock than my stock one Perhaps they did a couple of different styles over the years.
    Nikita the RA23 is almost finished .
  12. #1257
    Hey Guys,
    Finally uploaded some pics of the 18RG toady. Back from the machine shop all balanced and ready for assembly. Check them out on my rebuild thread.
    Ren.
  13. #1258
    Quote Originally Posted by Steve M
    88251 = 8.7:1
    88270 = 8.3:1
    casting reads 88270 as i said before this has had a interesting life
    rep to all
  14. #1259
    Probably 8.3 then mate... but you have the good head at least.
  15. #1260
    do you reckon it'll go well with the 8.3 pistons and yes aslong as i have the 230 cams im happy
