Time to add an informative post of the pictorial kind
Here's some info for the 18R-GEU guys wondering what all the ports are on your intake manifold.
In the pictures above:
- This is the main PCV port, as seen in this pic, it connects to the cam cover PCV outlet. The port on the manifold actually routes to in front of the throttle, not directly into the plenum.
- This is the input for the idle up valve - see http://www.18rg.com.au/tech/18rgeu-diagram.jpg - the other side of the idle up valve connects to the port underneath the throttle body.
- Brake booster vacuum line
- 3-pronged vacuum line outlet, for fuel pressure regulator and boost gauge. The other is blocked.
- Single vacuum line outlet, for my ECU. In this location used to be the air-con idle up valve - a VSV controlled diaphram that increases idle when your air-con compressor kicks on.
- Crank case breather outlet on the block. I've got this running to an oil catch can, partially visible under the intake pipe.
- The other side of the catch can runs to the intake pipe, pre-throttle
- These two vacuum port outlets on the throttle body, one goes to the vacuum advance on your dissy (i dont have this, cos my computer controls ignition advance), and the other goes to your charcoal canister.
Note the two outlets above the throttle body that arent connected. These circulate coolant around the throttle for emissions purposes, and also impede power output - disconnect them.
It's also worth noting that I have removed and blanked off the cold start injector. I never visit sub-zero temperatures, so i see no need to keep it.
but anyways, good info and helpful for anyone who cares to look (and has an 18RGUE setup to install)
So it's not an 18R-GEU retrofitted with carbs, I'd say it started life as a complete 88251, then somewhere along the line the head shit itself so they sourced a 88270 head as a replacement.
