Page 276 of 392 FirstFirst ... 176226266274275276277278286326376 ... LastLast
Results 4,126 to 4,140 of 5875
  1. #4126
    Using the Mk1 eyeball technique, you can get the cams pretty close by lining the cam notches up with the cam cap arrows, with the top of the chain and the exhaust side taut and the crank at TDC. Small adjustments from there should be made with a dyno run.
    As for the valves, if you rotate the crank 1 revolution so the cams are pointing in the opposite direction, you should be able to measure the other 4 valves. It is important that all valves are measured and are within spec.
  2. #4127
    Ballarat Vic
    Quote Originally Posted by o_man_ra23 View Post
    Sw sell new tensioners. A retarded exhaust will make the intake go straight out and lower the compression reading. Rings not bedded won't help the compression either. Have you checked the valve clearances with a feeler gauge?
    So SW sell top tensioners as well the bottom one???
    How about guides???
    Roscos
  3. #4128
    I'll ask them tomorrow morning if you want roscos. Cool o man, will get on it tomorrow
  4. #4129
    Guides... no. I believe they are working on getting a supplier to re-coat them possibly. Top tensioner doesn't look like the original, but does work.
  5. #4130
    highly underrated Backyard Mechanic
    Feb 2010
    i never knew these were so sensitive. i didnt have much info when i put mine back together so i assume its all timed up correctly it was going pretty good second last time i ran it but last time it ran like a welshman and started backfiring under load under 3k then cleared up once it revved up over that just like it was after i got the exhaust done.
    got no time for it anyway working 3 jobs and with 2 kids my plate is full atm.
    btw whats the factory efi manifolds worth these days?
    RT104 with 4AGTE
    Some assembly required
  6. #4131
    Top End
    well if someone didnt know what it was you might get it for $20
    but since the last ones in existence are lock away in secret bunkers good luck finding one
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  7. #4132
    yeah those EFI manifolds are getting harder and harder to find.
    Its soon going to get to the point where custom manifolds will be cheaper and easier.
  8. #4133
    I sold mine for 600 about 3 months ago
  9. #4134
    jeesus - that is almost custom manifold territory.
    i guess i might have to sell mine eventually too.
  10. #4135
    Thats an allen head bolt welded into the tensioner housing. If anyone knows of Andre in Perth building a black RA23/ RA28, feel free to pass on his details.
  11. #4136
    Top End
    OMFG that is some sexy "Agrineering" woohoo
    Adjust makeshift tensioner using spacer
    weld in place
    Profit
  12. #4137
    thats a pretty tough looking unit at the top - whats that from?
  13. #4138
    Top End
    SW motorsports/modified 4ME from the looks
  14. #4139
    From a 4M, as suggested by Stewart Wilkins himself
  15. #4140
    Top End
    it looks a little long ???? paybe just compared to the dodgy one
    i think you might need to shorten the rod if its a stock 4ME one
