Results 1 to 4 of 4
Thread: Jzz30 Engine Loom Questions
    Default Jzz30 Engine Loom Questions
    Hi Guys
    I'm currently tidying up my 1jz conversion, using a jzz30 loom.
    I've removed a few un-needed connections, and i have 2 remaining that i am unsure of.
    There is a 2 pin black connector, takes off just after the firewall connector, before the map sensor. Wire colours are Black/Yellow & Red/Blue, they trace back to the 12pin white dash loom plug.
    Also...
    2 pin grey connector, takes off with starter solenoid & knock sensor wires.
    Purple/Red - traces back to 23pin orange dash loom plug.
    Brown/Black - traces back to 25pin white dash loom plug.
    Probably sounds pedantic, but i just like to know where everything goes.
    Seeing as they dont connect to the ecu, im assuming they will be irrelevant...
    But it would only be a 2min job to open the bonnet of your soarer and have a gander.
    /end rant
    -Phil
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: Jzz30 Engine Loom Questions
    2 pin black connector will more than likely be the VSV valve for the heater tap
    2 pin grey connector will more than likely be the oil level circuit
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Thanks Manny!
    They would both make sense
    -Phil
    Manny's on the money that what I would have said.
  1. 4agze solid engine mounts, oil cooler/relocator kit questions
    Last Post: 03-10-2006, 05:49 AM
  2. Cooling Systems - Overheating Problems.
  3. rn40 hilux engine and gearbox questions
    By vanman in forum Tech and Conversions
    Last Post: 09-04-2006, 06:07 PM
  4. GA70 loom questions.
    By thomasbl in forum Tech and Conversions
    Last Post: 12-02-2006, 01:42 PM
