Results 16 to 30 of 54
Thread: 3RZ-FE Gearbox options
    Default Re: 3RZ-FE Gearbox options
    spring load scale ..... hang the motor off it
    Black Betty >HERE!<
    (\__/)
    put all on a ute
    get weighed
    remove engine, get weighed again.
    User Conversion King
    NWA
    hello
    wa
    i have industrial scales at work that i can use to weigh my 3rz motor and box next week
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Okay cool, thanx for your help, I'm considering putting 1 into a ta22,
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    as has been asked in another thread, similar to putting one into a RA28, it just wont fit without dry sumping it. even then, it still wont fit under the bonnet.
    NWA
    Quote Originally Posted by -==L=a=N=c=E==-
    hold that thought for a while. since RA40 engine bay = RA28 = RA23, i think it will fit
    ive measured my 3RZ and it looks like it will fit on one condition; the plenum and piping cant be higher then the top of the cam cover. ie it will need a custom plenum straight up
    there looks to be about 5-10mm clearance once its in.
    the 3RZ looks about the same height as the 1GGTE with the intake plumbing across the top of the engine.
    give me a couple months to prove/disprove this
    i think i may have to atleast slightly trim the rear of the sump to clear the xmember (prado = front sump)
    hello
    I was gonna go custom intake manifold with front mounted throttle body, I have a front sump that will need to be chopped a bit for ground clearance - it was from some 4x4 and has a very deep section so I'll have to shorten the pickup too...
    vic
    I think i have a 3 RZ manual w56 bellhousing id sell .
    Dave
    Dave: yeah? how much and where are you?
    Rosewood
    is it just me, or has the 3rz become the new hotness?
    i think that since peoplel started turboing them and getting huge numbers it was destined to become the new hot enigne to modify
    Yep big hp and still a four cylinder caught my eye
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Quote Originally Posted by ONCE-NA
    Dropping the amount of oil in the sump does'nt sound like a really good idea dry sump would be a better idea. They make kits for them. Just gotta spend the money.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    NWA
    my reasons are:
    -overall weight and length (better weight distribution)
    -cheap rego
    -capacity- 2.8 is about the biggest FI engine you can put in a RA40 AFAIK
    -no dizzy trying to sit in your dash (ie 3sgte)
    hello
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
  2. gearbox options for engine conversion
    By lowlux69 in forum Engine & Driveline Conversions
    Last Post: 10-11-2007, 03:15 PM
  3. ae92 20v gearbox options
    By d3v147 in forum Tech and Conversions
    Last Post: 22-04-2007, 01:23 AM
  4. AE86 Gearbox Conversion Options
    By Garth AE86 in forum Tech and Conversions
    Last Post: 20-03-2006, 01:30 AM
