Results 31 to 45 of 54
Thread: 3RZ-FE Gearbox options
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Default Re: 3RZ-FE Gearbox options
    Like he said, largest capacity motor (with forced induction) that I can have. And I have a spare motor from my work ute here.
    I was thinking of winging the sump too, gotta get a TA22 shell from my parents joint to see how it will fit, or if I will need to go dry sump.
    Its either that or a *Hock spit* SR20
    3TGTE is a bit limited
    vic
    Sth east melb , $100
    Dave
    Quote Originally Posted by ONCE-NA
    *cough my sig *cough
    Hoskin: Hehehe
    Got a new clutch put in my work ute yesterday 'cause I just couldn't be stuffed and took the day off to work on the TA22, Went to pick it up and I remembered why I usually do things myself. over $800 parts and labour, granted he did a few other things I didn't ask for but were a good idea at the time.
    Anyways I kept the old clutch to see if it would work for the 3RZ to W57 i'm contemplating.
    The gearbox spline is much larger than the W57 and more splines and the coverplate to flywheel bolt holes are slightly out and the W57 T-series friction plate is slightly smaller in diameter.
    I rekon you could use the 3RZ flywheel and cover plate, the T-series friction plate and the W57 to make it work...
    User Conversion King
    NWA
    the whole 3RZ manual flywheel and clutch plate and PP will work without mods.
    wouldnt bother stuffing around with T series crap
    hello
    The clutch plate, from my 3RZ ute would not fit either of the 2 W57's I have here, WAY wrong spline!
  8. #38
    NWA
    sure?
    i have a complete clutch/bellhousing/PP from a 3RZ out of a prado with a W56
    i was under the impression the input and output splines of all the W5x series were the same
    hello
  9. #39
    should be if richard runs a w58 on a w56 clutch?
    w57 excused haha
  10. #40
    I'll take a few pics 2moz
  11. #41
    wa
    does the w57 have less splines on the shaft
    maybe possible to swap input shafts
  12. #42
    yeah less splines, but fatter shaft too!
  13. #43
    i have used w55 w56 and w57 all on the same clutch. i can never find a w58 when ive the old box out.
  14. #44
    The Hilux plate (W56)
    http://a456.ac-images.myspacecdn.com...fccd7f11df.jpg
    And my old one from the celica (W57)
    http://a226.ac-images.myspacecdn.com...8313a33781.jpg
    Sorry about the dodgy camera- phone pics..
  15. #45
    all of mine look like the hilux plate, ive got 6 clutchs sitting here.
  1. Verifying a w58 gearbox
  2. gearbox options for engine conversion
    By lowlux69 in forum Engine & Driveline Conversions
    Last Post: 10-11-2007, 03:15 PM
  3. ae92 20v gearbox options
    By d3v147 in forum Tech and Conversions
    Last Post: 22-04-2007, 01:23 AM
  4. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
