Results 1 to 7 of 7
Thread: ra65 rack and pinion power steering rack
    Junior Member Grease Monkey Intense's Avatar
    Default ra65 rack and pinion power steering rack
    I need to replace my steering rack, what I need to know is, does it have to be from an ra65, or can I get one from a powersteering ra60/sa63. Or are there any other cars that have the same steering rack? Also what price would I be looking at for a second hand one?
    Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
    Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
    Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
    Default Re: ra65 rack and pinion power steering rack
    EPC says
    ST141, RT142, SA63, RA6# are the same.
    I'd still check this first hand but that is what the EPC says
    as if a6's need p/s!...wouldn't mind one in my car sometimes...would make the bigger tracks a bit easier to drift
    Toyota Celica JZA65 Drift Car
    KAIZEN GARAGE - QLD agent for Adaptronic ECU
    spaRk secRet - HID headlamps
    Montrose
    Quote Originally Posted by timottaway
    If you don't appreciate power steering, then you're not running enough castor.
    I've had issues with swapping an RA60 rack before, I remember there being differences and having to try a couple before I found one that fitted. Sorry, I can't remember exactly what the issues were though.
    MA61 isn't the same as SA63 etc that I can say!
    But yeah i'd still check to make sure!
    Quote Originally Posted by mrshin
    I like that, sounds good.
    yeah i've run 4.75 degrees and that was with a locker....far too heavy
    nothing more than 4 is required for a celica this together with p/s far too light....
    its a good setting to stop excessive dyanmic camber once a bit of lock is dialled in..
    from experience in a track environment, p/s failures etc fair outweigh there advantages. non p/s rack with p/s arms give a quicker rack and more direct steering feeling and a better feeling of castor and steering angle.
    i'm extremely bias i'm quite the non p/s diehard!
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 11:02 AM
  2. Can you adjust steering stops with rack & pinion?
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 22-07-2012, 01:30 AM
  3. rack and pinion
    By bigmat in forum Tech and Conversions
    Last Post: 18-04-2007, 08:33 PM
  4. Which power steering box is going to fit a 22.
    Last Post: 19-06-2006, 08:16 PM
  5. rack and pinion steering - new pinion? from where?
    Last Post: 20-05-2006, 06:14 PM
