Results 1 to 5 of 5
Thread: jzx81 wiring diagram
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default jzx81 wiring diagram
    Hey can someone point me in the direction of a wiring diagram for the ecu setup on the jzx81 as i need to set it up in a mx73. have tried a search here but dont seem to get anything.
    Also does the auto need the electronic speedo sensor to run correctly and if it does how do people get around the problem of a mechanical speedo drive?
    any help would be good
    Pete
    penrith nsw
    Default Re: jzx81 wiring diagram
    wiring diagram now sourced thanks just need to work out the speedo
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    Be carefull there are some dodgy diagrams out there for the 1JZ (do not run "fpr" to ground)
    MATT.
    Junior Member Chief Engine Builder wiso's Avatar
    Quote Originally Posted by pete05
    Pete
    a bit more info would be good, i guess your using the auto from the jzx81? that normally uses an electronic sender/speedo, but your car (mx73?) has a mechanical cable and analogue speedo? am i correct?
    if your old auto is an a340 series, and the new one is also (probably an a340le?) if the extension housings look the same (ie. speedo drive goes in at the same point) you could probably use you mechanical conction in that box. if not you may be able to swap your extension housings over and use it, while off check the cog in the box make sure they are the same or similar.
    this is just a guess, as i interchanged parts from 3 differant a34* boxes when i was stuffing around to get one working properly in my supra. they all seemed the same at the extension housing section even though they were all from differant cars
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    penrith nsw
    cheers guys i think i have the speedo drive worked out now
  1. Needed! - RA63 Wiring Diagram
    By Spectre in forum Tech and Conversions
    Last Post: 06-09-2006, 10:54 AM
  2. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
  3. URGENT!!!!!! AE82/92 4AGE (MAP) Wiring diagram
    By Schmitt in forum Tech and Conversions
    Last Post: 05-07-2006, 04:08 PM
  4. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  5. i need a ST185GT4 wiring diagram or pinout
    By tai_180sx in forum Tech and Conversions
    Last Post: 17-02-2006, 12:27 PM
