Results 1 to 14 of 14
Thread: URGENT!!!!!! AE82/92 4AGE (MAP) Wiring diagram
    Junior Member Grease Monkey Schmitt's Avatar
    Unhappy URGENT!!!!!! AE82/92 4AGE (MAP) Wiring diagram
    Hi guys
    As the title says i am looking for a AE82/92 4AGE (MAP) Wiring Diagram. This is urgent as i have been looking for a while and cant find one, and it is the only thing stopping my car from being wired up. I have the workshop manual but it only has the AFM motor wiring diagram.
    If anyone has one please post it here or pm me.
    Thanks very much
    Ben
    Founding member of SPOOT RACING
    Schmitts 4AGE TA22
    Default Re: URGENT!!!!!! AE82 4AGE (MAP) Wiring diagram
    you mean you need an ae92 map wiring diagram?
    Hi kingmick.
    Why do you say that. Did the ae82 not come out with a map sensored motor. Cause when i went to toyota today to see if they had a wiring diagram they confirmed that the AE82 came out with a map sensored motor.
    Schmitts 4AGE TA22
    it will be the same as a ae92 one
    unless you need the body wiring! or the same as an mr2 map one
    Awesome. Good to know.
    Thanks
    Ben
    Schmitts 4AGE TA22
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    The AE82 indeed came with a map sensor - I have one in bits in my shed.
    Default Re: URGENT!!!!!! AE82/92 4AGE (MAP) Wiring diagram
    Anyone?......
    Schmitts 4AGE TA22
    The ECU pinouts are here: http://www.club4ag.com/technical_mai...s%20and%20Data on club4ag. And http://www.soniccreation.com/ also has some good wiring diagrams.
    When all else fails you can trace the wires using the colours and the pinouts from the ECU. Also if you unscrew the top cover of the ECU then all the pinouts are printed on the circuit board.
    Thanks takai
    For some reason when i open the soniccreation website the menu on the left wont show up/work.
    Any more diagrams/websites
    Ben
    Schmitts 4AGE TA22
    That would be because you dont have the right version of Java installed on your system. Im pretty sure they use Java 5.0
    Ok thanks
    bump
    Schmitts 4AGE TA22
    Traditionalist Domestic Engineer parrot's Avatar
    I'm pretty sure I have these, will look tonight. PM me a fax number or address to send a copy.
    Thanks Parrot
    PM Sent
    Schmitts 4AGE TA22
  1. AE82 4AGE Wiring Diagram/ECU Pin Outs
    By Schmitt in forum Tech and Conversions
    Last Post: 31-05-2006, 11:03 AM
  2. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  3. Wiring diagram for 4age
    By Sigg. in forum Tech and Conversions
    Last Post: 17-01-2006, 09:08 PM
