Results 1 to 15 of 18
Thread: Has anyone modified a standard 20v silvertop ecu?
    Junior Member 1st year Apprentice boon280's Avatar
    Apr 2007
    S.A
    Default Has anyone modified a standard 20v silvertop ecu?
    Just interested to know if the Stock toyota 20v ecu can be reprogrammed like the commodore delco computers?
    I have done a fair bit of searching and never read anything about this being done, but that doesnt mean its not possible.
    Default Re: Has anyone modified a standard 20v silvertop ecu?
    can't be done easily... toyota ecus have their eeprom internally to their microcontroller.
    Apr 2007
    S.A
    Ok sounds like something I know nothing about, I am running a stock silvertop in my offroad racing buggy and just trying to get some small gains from it as there are 3 other guys locally running stock engines and ecu's that I wouldn't mind getting an edge over.
    Any ideas for some cheap tips on gaining some performance?
    Put in some jungle juice and get a piggyback controller to adjust your ignition timing?..
    Water injection to raise static compression ratio?
    Tuning the length of your exhaust and intake tracts? Swap in a Blacktop 20v?
    I'll only guarentee the last option for a definate power increase
    Apr 2007
    S.A
    Yeah I cant run any "jungle Juice" cams rules say pump fuel only.
    Water injection , too heavy and complicated,
    Exhaust is probably as good as I will get it and the blacktop doesn't sound very cheap but thanks for the help anyway, I'm rebuilding a spare engine shortly and will probably just tidy up the inlet ports and manifold and i'm trying to see if there are any cams that will run with the standard ecu and vvt.
    Apr 2007
    S.A
    Got any info on the piggyback controller sounds interesting?
    probably best doing a search or finding someone who has used one as I technically haven't had any experience with one
    i did awhile ago
    i put a hammer straight thru it
    reason delco ecus are progreammable is that there are actually many many people out there mainly in usa who want to tune them so demand is very hi
    where as toyotas might not be so much of a demand world wide
    and also because toyota might have a much hard code to crack
    where delco is usa based cars and they dont give a rats asss who fucks with there ecu
    but when u look at what u can adjust in a std ecu like a delco there is over 20000 minute adjustments for this and that
    Apr 2007
    S.A
    Hammer ! thats funny, I figured that there isn't as many 20 valve ecu's as delco's so the chance of people bothering to crack it would be pretty slim but if you dont ask you dont know.
    It's not just demand, it's also difficulty. Being able to reverse engineer something with a DIP eprom socket is much easier than something fully contained. There are piggyback ecu's that have injector drivers built in to allow more flexibilty... however probably not required as you haven't really modified the motor.
    I use a Jaycar DFA with my 20V ST and by leaning out the mixtures slightly (done on the dyno with WB oxy sensor in place) as it was running rich up top they gained 3-4kw across the entire rev range. What are your mixtures like?
    Julian
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    ideas for squeezing out a few more killowatts:
    -run an electric water pump
    -use lighter oil
    -use some exhaust heat wrap
    -try the 98 octane E10 fuel? (if they allow it, it is "pump" fuel though) its bound to allow a bit more advance and will effectivly lean it out a little bit, whether its by too much or not - unknown but the computer could compensate automatically?
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Apr 2007
    S.A
    This looks interesting,I will try and contact them and find out some more info.
    I am really keen to keep the toyota ecu on the engine as I beleive that toyota must have spent millions of dollars developing these systems and they are just so reliable, but I still want to make it go better !
    Apr 2007
    S.A
    Quote Originally Posted by FMS01
    Julian
    The engine has never been on a dyno or had the mixtures checked but I will be playing with it soon so it will be interesting to see what I can achieve.
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 08:10 AM
  2. Blacktop ECU on a Silvertop
    By Escy in forum Tech and Conversions
    Last Post: 03-03-2007, 09:13 PM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 07:31 AM
  4. 2jz-gte pinging - was gt35/40 with standard ECU
    By Draven in forum Tech and Conversions
    Last Post: 13-07-2006, 03:07 PM
  5. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 11:17 AM
