Results 16 to 18 of 18
Thread: Has anyone modified a standard 20v silvertop ecu?
    Default Re: Has anyone modified a standard 20v silvertop ecu?
    Quote Originally Posted by boon280
    The engine has never been on a dyno or had the mixtures checked but I will be playing with it soon so it will be interesting to see what I can achieve.
    See also this thread
    http://www.toymods.net/forums/showthread.php?t=21815
    New Zealand
    if you keep an eye out on ebay there are some factory modafied ones with
    higher redline and different timing was one on trademe befor sound like it could be just
    what you need
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    I heard that if you don't have the speed signal from the speedo the ECU will give a lower rev limit. Racing a 20 valve, you would want the rev limit up around 8200rpm I guess.
    Once I get to modifying my 20 valve, the first thing I want is very big cams and adjustable cam gears. The rest is fine tuning. But only after a fully programable computer of course.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. Blacktop ECU on a Silvertop
    By Escy in forum Tech and Conversions
    Last Post: 03-03-2007, 08:13 PM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  4. 2jz-gte pinging - was gt35/40 with standard ECU
    By Draven in forum Tech and Conversions
    Last Post: 13-07-2006, 02:07 PM
  5. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
