Results 16 to 30 of 39
Thread: Why does my 1g keep blowing ignition fuses..
    Default Re: Why does my 1g keep blowing ignition fuses..
    Maybe this was telling you its bad mmkay.
    The original way you had it wired up made the fuel pump run under all conditions as long as ignition is on? Even when the cars on its roof and the fuel line is cut and its a blazing alight?
    Or am i missing something?
    Who wired this up? Looks well dodgy. COR would have been easier if anything
    No No thats about it..
    Look, i know its dodgy, hence trying to fix it.. the reality was that i needed a car or else i would miss a lot of uni and work, as i also tutor a class at uni, i would have probably lost my contract if i missed a class..
    I needed a car, now i got one running, now that i have a little more time i can try to fix it..
    Stomps
    what ign fue it is
    there is an efi fuse?
    run pump straight of battery thru a switch temporarily and see if it still blows fuses
    if it does then yr engine wiring is fukt
    hehehehe
    you also might have bad power to the injectors/coil system and overlaoding the wires
    another thing is is there any tight wiring
    maybe ubder load the engine torques one way pulling on tight wiring and shorting it out
    seen it done many times by backyarders
    tell me exactyly what fuse is blowing and il tell u what it runs if it was wired corectly
    u should never have to run 2 or more relays for a single fuel pump
    What could be causing this?
    Dodgy wiring!
    What gauge wire has your 'mystery' autoelectrician wired into at the ignition barrel?
    Run a wire from the FPR output of the ECU to the circuit opening relay, and replug in the factory wiring.
    Now, check what wiring the injectors are getting their +12V from.
    Quote Originally Posted by BlackSupra
    Dodgy wiring!
    He's no mystery, he's elmo!
    http://www.toymods.net/forums/showth...t=13822&page=8
    User Conversion King
    NWA
    i triggered my fuel pump relay from the AFM open wire.
    hello
    I think thats what I did in the end, and I replicated that with my Adaptronic.
    ok so dont power injectors from ignition?
    ive got power into AM2 and out to INJ on IG2 ... nothing else on IGZ wire though.... will this do? Or do i need fused power from battery and use IG2 to trigger a relay?
    Black Betty >HERE!<
    (\__/)
    I can't remember, mine is wired up however my factory wiring is
    1G std wiring shows IG2 straight to injectors through F1 connector. No fuse no relay. Earths get cycled via ecu.
    Edit: what would 1 estimate as the injectors AMP draw?
    Black Betty >HERE!<
    (\__/)
    In that case, I found the wiring that did that at my ECU and wired it up appropriately.
    ok, its nothing to do with fuel pump.. i rewired it last night and it still blows fuses..
    for the record its the IGN fuse in the internal fuse box.
    MORE INFO..
    Fuse blew last night again, i waited a bit and tried a few more fuses, all blew, i noticed that my little green light in the interior stays on all the time, no matter if doors closed or open, keys in or out.. This runs off the DOME fuse in the interior fuse box.
    Furthermore i have had issues with my headlights for a while, they were not touched during the conversion, but they seemed to stop working after.. After the drama last night as i was looking for fuses, i looked at one of the headlight fuses and it was blown. I noticed that the IGN fuse was still in tact but the car wouldnt start...
    As soon as i replaced the headlight fuse, tried to start the car and all was good..
    WTF?? what car be running from the headlight? We didnt touch the fuse box or anything around there?
    Stomps
    HAHAHA You have one fucked up wiring job going on. Maybe take it to some who will and can fix it properly. Not saying Elmo cant but thats sounds really fked.
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. 1jz ignition
    Last Post: 04-07-2010, 08:25 PM
  3. Replies: 5
    Last Post: 21-12-2006, 09:46 AM
  4. Ignition prob/missing 2tg - Help please auto electricans?
    By poida in forum Tech and Conversions
    Last Post: 31-10-2006, 09:08 PM
  5. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
