Results 16 to 22 of 22
Thread: 1jzgte electrical issue
    Default Re: 1jzgte electrical issue
    Quote Originally Posted by cambelt1
    What tacho booster are you using , sounds like somethings a miss with it .
    Dave
    I doubt it is the tacho booster, as you can see the IGf line doing silly things.
    The tacho output from the igniter doesn't goto the ECU...
    Also the car has done over say ~30000km with the same tacho booster...
    However it is that simply circuit that is floating around.
    Norbie: Yeah I think I'll have to try and find a JZZ30 ecu to try (know anyone?)
    Junior Member Backyard Mechanic manny's Avatar
    PM'd you mate
    GSE20 IS250 - daily
    Make sure the tacho booster has a diode on it.
    I used to get IGF errors intermittently til I added one.
    When my CAS was smashed I got that error too, so maybe check condition of CAS and its wiring.
    244rwkw / 328hp @ 18psi
    Quote Originally Posted by Ribfeast
    Was your tacho doing other crazy things etc?
    I didn't have a diode, but I've since added one... (I can't really see how this would effect it but hmm!)
    It did crazy things when the CAS got banged up
    Tacho has always worked fine with the booster though, with and without diode.
    I might be barking up the wrong tree with the diode, I have other theories about why the ECU kept popping that error: The timing was out by a whole tooth on the crank itself (pulleys were ok though).
    Just going out on a limb but the timing being out a whole tooth on the crank might put the spark so far out of wack that proper ignition (and hence IGf) wasn't occurring?!
    Still worth a try
    It would only set the code once every few weeks though, odd aye!
  1. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 08:32 AM
  2. Walbro Pump - Cause - Alternator Overcharging!!!!
    By sbyder in forum Tech and Conversions
    Last Post: 09-10-2006, 09:15 AM
  3. JZA70 1JZGTE Engine manual ? Anyone
    By 1200det in forum Tech and Conversions
    Last Post: 12-08-2006, 09:57 AM
