Results 1 to 14 of 14
Thread: '86 mr-2 brake upgrade options
    AB
    Default '86 mr-2 brake upgrade options
    so what options do i have? what is going to be the easiest to get done. i spot a few tidbits on the net every now and then that i can use 88/89 brakes but i want to know if this is worth it or if there is a better option. i currently am running stock rims but am willing to change if it gets me better braking.
    thanks in advance.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Default Re: '86 mr-2 brake upgrade options
    i remember reading somewhere that ST185 brakes fit with a little hub modification... but yeah someone confirm that for me!
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    New Zealand
    first thing is why do you want better brakes?
    if its for road use then maybe a noverhaul and good pads is all you need?
    for racing there are several options, st205 front brakes, sw20 rears, need 16s to fit st205 fronts though.
    please, no more PMs!
    Junior Member Carport Converter Mooro's Avatar
    Tasmania
    I haven't fully research this so don't quote me on it but my plans are to use ADM ST185 (big single piston calipers and bigger rotors) rotors and calipers up front, then use me front disk on the rear with SW20 rear calipers. I have been getting conflicting info with some people saying all of that is a straight bolt up affair, others say there are so mods needed. If you do go down that path I'd be keen to hear how it went.
    Quote Originally Posted by Mr Revhead
    you can never have enough stopping power imho!
    AB
    Quote Originally Posted by hamgatan
    Thats kinda where im at. This car HAS TO remain streetable but I do want to use it for weekend autocross and straight line racing.
    is the most useless Backyard Mechanic jonchai's Avatar
    st205 brakes are MASSIVE....way overkill for an mr2....
    i know you want/need big/bigger brakes..but mate..this is one big mother. had wheel clearing problems in my st162. otherwise a bolt-on....not ure about mr2
    Performance Through Technical Supremacy
    (\__/)
    hehe
    AB
    i think what i will do is make a couple of templates/take some measurments and head to the wrecker and see what i can spot. so much toyota stuff is compatable i should be able to get what i want and have it (close to) bolting right on.
    New Zealand
    well, as i said it depends on application.... i know of a few aw11s that can make use of the st205 brakes.
    i also know that most can make do with just an overhaul and some decent pads.
    how are your tyres? suspension?
    cant make the most of your brakes in those arnt up to it
    for autocross and what sounds like dragracing, id say stock with good pads will be enough
    mine had stock brakes and was plenty good enough for the hills near home, which are steeper and tighter than anything yo uhave over there!!
    AB
    I found these on ebay today. http://cgi.ebay.ca/ws/eBayISAPI.dll?...0075&rd=1&rd=1 not exactly an upgrade but being slotted and drilled they should help with pad wear and tear.
    not sure if your hills are steeper and tighter but i can tell you i live in a town called Rocky Mountain House, it has the name for a reason.
    Junior Member Domestic Engineer dandan's Avatar
    May 2006
    The NZ hills are great! Wouldn't mind taking the mr2 for a spin round them. If its not raining...
    The only thing I've found when upgrading the brakes is either to keep the stock ones and get better pads/rebuild the calipers or go get something with a larger disk and larger brake pad, if you can't get anything bigger than stock there's no point.
    I wouldn't worry too much about brake fade. The 87+ brakes are more than up to the job. Has anyone managed to make them fade??
    Oh wait, you have the 86 model. I'd go with the 87+ calipers + disks as there's less messing around and its a simple swap.
    AW11, aus spec 1987
    What is the legality of sea food extender? I know you're not allowed to have a quick feast in a street car but am unsure of just the extender.
    As said the late model AW11 brakes are quite decent and a significant upgrade from the early stuff.
    Personally I'm running sigle spot ST185 front callipers with redrilled ST185 front rotors. On the back I am running SW20 gen3 turbo rear callipers with AW11 front rotors and a spacer to make it align.
    wa
    ST185 twin pot calipers WILL fit the standard hubs with NO modifications, you can keep the standard discs also.
    i am running this setup, the swap was as easy as removing original ones and bolting in new ones....
    you can use 15's with a high offset they still clear very well no spacers needed.
    also try some GOOD brake pads, like endless etc
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Junior Member Grease Monkey safeforever's Avatar
    hey, definately go for the st205 fronts!! wonderful upgrade, stops like nothing else!
    apart from actually finding parts, the conversion is really easy! (see here for my upgrade: http://www.toymods.net/forums/showth...ght=aw11+st205 )
    and who cares if people say its overkill?
    so worth-while
    although you will need bigger wheels...
    By The Witzl in forum FAQ
  2. mx83 brake upgrade; my pics
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 04-02-2011, 10:21 AM
  3. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 11:26 PM
  4. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 03:29 PM
