Results 1 to 12 of 12
Thread: xA23 & xA28 Bonnet hinges
    Junior Member Backyard Mechanic celicaboy_2000's Avatar
    Default xA23 & xA28 Bonnet hinges
    OK, while I was fitting up my bonnet I noticed that my lefthand (P/S) hinge is smaller in length then the D/S hinge is that normal? And the gap between the bonnet and plenum shows that it could use another 5-10mm in length. Is there differences between the celica families with this sort of hinge. Could I get a couple you guys to measure both your hinges and let me know what you have? Cheers
    Default Re: xA23 & xA28 Bonnet hinges
    Celicaboy,
    You may have a TA22 and an RA23/28 hinge, ie one of each. Dispite popular opinion the hinges are different on the TA22 to the xA23 and RA28.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Its hard to measure accurately whilst they are on the car but does 180mm with the bonnet open sound about right.
    There are different hinges from ta22 to ra series from memory
    Measure the distance from your firwal to the top radiator support panel and see if they are the same both sides.
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    My RA23 hinges are direct mirror images of each other.
    I reckon, like rod said, you've got a TA22 one there somewhere.
    (\__/)
    (")_(")
    i've seen similar things myself!
    I pulled a pair of bonnet hinges off a TA23 and went to fit them to my RA28 - no go.
    I am not sure if they were TA22 ones bunged onto a TA23 or what, but they didnt fit.
    REASONS - the face that bolts to the headlight mounting panel was a lot FLATTER on the TA23 one when compared to the RA28 hinge. The RA28 hinge has a distinguishable "step" on the inside lower mounting face on both hinges.
    I tried fixing this with a washer..... only to find they are shorter too.
    CONCLUSION - bought some brand new hinges from Phil from CCG
    ...... butt scratcher?!
    My new D/S hinge measures about the 175mm so bout the same as airfireman1, where as the P/S hinges measures about 155mm, can anyone measure there TA22 hinges and let me know what measurements you get? But what I can work out and what you guys are saying it must be a TA22 hinge
    Just got of the phone with Toyota, apparently early ta23 use the same hinges as ta22 and that they changed about the 76 era to the longer type. So if you have a good RA23/28 hinge PM me.
    Junior Member Backyard Mechanic leso's Avatar
    Matt....no wonder i had so much trouble with them hinges ...just checked the brother to the one i sent ya...about 10mm less when fully open than the one on my orange ra23...which i believe to be all genuine. karl is right the ra23 one has a VERY distigushiable step when compared to a (22) one...soz mate..
    i do have a spare set in v/good nick that i was keeping for my orange one...but the hinges on that are not to bad so.............mmmmmmmmm
    PM sent Leso, your a hero once again.
    in the mail 2morra mate...btw found them little grommet things you needed, in the same package..
    RA23 and RA28 hinges have a very distinguishable step for one bolt hole in their mounting onto the body.
    (\__/)
    (")_(")
    Thanks everyone, hopefully when I get this other hinge i'll have bonnet gaps...
  1. Broken bonnet latch
    By pr*duct in forum Tech and Conversions
    Last Post: 15-01-2007, 09:53 PM
