Results 1 to 4 of 4
Thread: Black Gold. Texas Tea.
    Default Black Gold. Texas Tea.
    I just found the part where the 2 rear sparkplugs on the 3TGTE goes is full of oil. There's obvious signs of a fair amount of oil blowing out of the rocker cover seal at the back. It's covered the firewall a fair bit. I've never taken the rocker cover off before. Just wondering if it'd just be a rooted gasket or something more sinister. Would a buggered rocker cover gasket allow oil to get into the well where the sparkplugs are? It's only the back 2 plugs that are affected.
    Where would I go to get a new gasket for a 3TGTE?
    Cheers, Greg.
    Default Re: Black Gold. Texas Tea.
    VERY common problem I found with my 3T. Even new gaskets if not aligned and installed just right would leak like yours is.
    Look up Stewart Wilkins Motorsport he carrys gaskets.
    A new one will fix the problem, just make sure when you install it that it doesn't slide around and move and stop sealing.
    The original Toyota ones I found better as they had little tags to hold it in place better.
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Thanks Joel.
    Anyone know somewhere closer to the south west for the gasket? Otherwise it's a trip to Windsor for me.
    Cheers, Greg.
    Just get Stewart to send it to you. Make sure that the surfaces are clean, any oil that is on the surfaces will promote a future leak.
    Johnny always uses Permatex No3 on his and it seems to work well for him. Like Joel has said though "makes sure that it is aligned".
  1. Car alarm wiring - Black widow BW10000
    By davedave in forum Tech and Conversions
    Last Post: 12-12-2005, 12:23 PM
