Results 31 to 45 of 49
Thread: Hi stall converters without a trans brake. How to launch?
    Default Re: Hi stall converters without a trans brake. How to launch?
    Mr 1jz: what is the response like compared to a gt35 1.06 like 2jzr31? I would think it would be a bit worse. If he is having trouble getting it on boost with a 2800 stall, I would ask Mike for the 3400 stall. That is if they do them for 2jz converters like they do for 1j's.
    QUICKEST 1JZ'S IN OZ
    yeah i have been told they do the 3400...I was gonna go 3200 as a minimum...4000 if necessary?
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Get the new turbo kit in, drive to MV's, get his advice
    Or check out what people use in the US with t78 size turbos. A lot seem to use the 3800 by Boost Logic but I think that is also for very large turbos.
    neg on driving there
    want to do it all in one hit...as in send car to Madaz to have turbo and computer fitted and get them to pull the auto box and stally when my car is there so I can send it to MV's to get all the trans shit done
    will I need to go bigger than a 3200 stally with the T78 that im going to put on my motor?
    just ask mike for the same as i have and you will be fine, or you can buy mine depending on your time frame, i am wanting to go to a billet convertor.
    8.3 et PB 169 MPH PB
    Quote Originally Posted by 2JZR31
    So Shane, how are you holding boost of the line?
    foot on brake, hand brake pulled up, hard on gas.
    every car is different, spend time at the track and work out whats best for you. i have driven heaps of different auto cars and they all respond differently.
    Quote Originally Posted by 1JZ.747
    excellent
    what size stally are you running shane?
    and how much would you be chasing for it?
  8. #38
    in the a340 boxes, power to the first gear solenoid is maintained in reverse. there is no dedicated reverse solenoid. The wire you would be refering to coming from the three pin plug @ front of gearbox is for the reverse lights ( wire comes out of inhibitor switch).
    My way of understanding is that a transbrake does lock first and reverse together, but i believe there is much modifying in the way of increasing the size of the passageways in the box to handle the extra flow and HEAT!. Reverse isnt just actuated electrically, but mechanically through the lever as well. To effectively lock these two together would involve machine work and mounting another solenoid to redirect fluid flow in the desired manner. Not a five minute job - but if anyone can nail it - Mike from MV will.
  9. #39
    Montrose
    I'd also suggest if you're trying to use Aussie R31 rear brakes, it's no wonder you have trouble as those are some seriously crappy brakes, plus the handbrake caliper would provide no extra help at all. Fit some decent rear brakes as a beginning point!
  10. #40
    Yes these brakes are utter shit.
  11. #41
    i worked out the other night at the drags, if i am hard on the foot brake, and use about 1/3 to 1/2 throttle it'll sit at about 2800rpm and then all of a sudden start to rise again
    The boobs are back
  12. #42
    Clutch pack slippage? Have you tightened or loosened your kickdown/line pressure cable? 2800RPM is about the limit of the stock converter I think unless you have super sticky tyres.
    244rwkw / 328hp @ 18psi
  13. #43
    i have a 2800rpm stallie now, but i could see 3200 on the stock stall
    The boobs are back
  14. #44
    Yeah the stock 1JZ stall is known to stall pretty damn high and the MV 2800 unit goes WAY over 2800 from all reports I have heard. The MV 2JZ 2800 doesn't stall anywhere near as high.
    Anyhow I am getting a MV 4000rpm stall for my car. Should be bloody awesome. It has a 2300rpm flash speed so should still be very steetable and it will have awesome top end as it has a worked lock up clutch that can be activated in the deep end at WOT. Costs $600. Should be worth it though.
  15. #45
    $600 is good, especiallyu if it has a better LUC
    The boobs are back
    By The Witzl in forum FAQ
  2. Stall converters for the 2J
    By 2JZR31 in forum Tech and Conversions
    Last Post: 31-03-2007, 06:24 AM
  3. Stall converters for A340
    Last Post: 03-09-2006, 07:50 PM
  4. Trans brake?
    By Cool1 in forum Tech and Conversions
    Last Post: 13-03-2006, 10:56 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
