Results 1 to 8 of 8
Thread: W5x to 4agze which clutch parts?
    Default W5x to 4agze which clutch parts?
    hey peoples,
    Im finally putting in my w5x box and im missing a few parts.
    Im missing:
    the rubber boot around the fork
    Thrust bearing
    Stupid clips that holds bearing onto fork
    slave cylinder
    The other thing is what car has the tailshaft i use? I just need the front half.
    edit: i also need a gearbox crossmember.
    Where can i get these from? Wreckers or toyota/parts place.
    Thanx heaps for you info +rep comming your way.
    PS i have searched.
    Montrose
    Default Re: W5x to 4agze which clutch parts?
    Which bellhousing you using?
    S.A
    Hes using the nite parts housing.
    He sort of started the question in the 4a to W5* thread...... so some info can be found there.
    Victoria, Mt Macedon
    From the top of my head:
    1) Rubber fork boot - use whatever fits, depends on the design of the bellhousing. You can always pull out the die grinder and make whatever you have fit.
    2) Thrust bearing - I can't remember right now, but I tried SA63 and GZ20, one worked. The bearing support thing was different between them so they had a different overall "length" I seem to remember.
    3) Clips - SA63. But I'm sure any W5* clips will work
    4) Slave - Again depends on the bellhousing. I use a mid 80s Liteace, which needed a new pushrod and spacing out from the bellhousing, but had the right mounting, shape and bore size. A trip to a good brake/clutch place with your box and bellhousing should sort this out though. They loved me when I heaved a W58 onto their counter.
    5) Tailshaft - Custom I assume. You can use the front yoke from any W5* box and get it put onto any shaft you like. I also just heard that an RA40 front half suits W58 into AE86 with T series rear end, so you may be lucky with something similar too. A trip to the wreckers will help there.
    6) GB crossmember - Custom again. Unless there is some rare factory frankenstein creation that happens to suit a W58 into a KE55.
    Where to get it all? A friendly wrecker for the clips/boot/etc. Go new on the clutch slave, they cost SFA anyway.
    Hen
    0402727834 Grease Monkey turbo ke20's Avatar
    cuzzo
    im in the boat as you.
    im making a custom x member
    i also need the uni that goes into a w series box
    i was lucky enough to get the fork, rubber boot, bearing and those clips that hold the bearing.
    its also got the slave on it, but then i dont think its a 1G bell housing so the slave may be different.
    justin
    i picked up the uni from pick n payless for 30 dollars. Just look on the build plate for the use of gearboxes such as w57 and w58 from the celica/supras. And unbolt the first half from the tailshaft as they are two piece. You may even find some in their boots as i threw one in there when i was looking for mine.
    Twisted ****** Backyard Mechanic .T.'s Avatar
    for the x-member - have a look at auto ke**- often the auto cars used the same mount etc as the w series box (ie auto ae86 has correct x-member for w series box) however this will also be dependant on length of bellhousing
    otherwise i typically use an ra40/60 xmember * rebox/weld/drill to suit
    T
    Well just to close this thread off.
    We made up a custom crossmember. Its getting the test now on how strong it is.
    I used a late model hilux throwout fork with standard w55/7/8 bearing and carrier. With a t18 slave cylinder without spacers. Just the rod isnt exactly perfectly pushing straight. On a slight angle. But it works!
  1. Creaking/Squeaking Sound on Depressing Clutch Pedal
    By Tham in forum Tech and Conversions
    Last Post: 29-10-2006, 08:04 AM
  2. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 09:12 AM
  3. W58 7M-GTE clutch choice
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 03-02-2006, 07:57 PM
