Results 1 to 15 of 22
Thread: normal runing tempature for a 1ggte?
    peru
    Default normal runing tempature for a 1ggte?
    hey i just fited an autometer temp gauge its been reading 110 degrees celsius i think thats way to high am i right?
    Default Re: normal runing tempature for a 1ggte?
    doesn't water boil at 100 degrees celsius
    yeh me thinks ur gauge / sender has issues.. is it a mechanical or electrical gauge?
    peru
    its a brand new electrical autometer water temp gauge
    Let me save you from the otherwise useless information provided above.
    The water temp gauge is reading fine.
    However, 110 degrees is pretty hot for a 1g, however you are probably in a pretty hot area of the world.
    Under pressure water boils at a higher temperature, and given the fact that it's got additives (I'm assuming you've got coolant in there) the boiling temperature gets even higher.
    My gauge tended to read 80 to 100 degrees, and it peaked to 110 in traffic, and even once pushed to 115~120 when I was stuck in traffic and it was a very hot day.
    Other than that, if you hover between 100 to 110, then you're probably fine.
    Facebook | LinkedIn
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Try putting a lower temp thermostat in it that should help
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    you should alos have the thermo fans cutting in and out round about the 85-95 degree temp range....providing they are working fine,
    as stated above, with coolant aditives and pressure, you riase the biloing point significantly....
    blake id get a lower thermastat too mine hangs around the 86 degree mark hits around the 90 mark in very heavy traffic
    cheers steve,
    1ggte, 11.22 @122mph
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    before changing the thermostat to something lower, id be looking at getting the radiator flushed, and give your cooling system a good clean out.
    coolant+water should boil at somewhere around 130 degrees celcius depending on the mixture.
    is it standard? do you have a fan?
    I have a Crown
    peru
    my fan is on 100% of the time took the thermo out and it still reaches 100 after lets say "spirited driving"
    if your having serious heating probs, remove the thermostat completely, to open up flow...but recomend replace it with a newer lower temp setting....
    i dont run a themostat....as ive got a davies craig electric water pump....
    around 85-90 should be right with an 82 degree thermostat. i was running an 87 thermostat and it would boil itself, the hotter ones let the motor heat soak and it cant cool its self
    what car is this in? im thinking your radiator is too small.
    these motors make ALOT of heat, you need a big, efficient radiator.
    Junior Member Domestic Engineer 1200det's Avatar
    Quote Originally Posted by stradlater
    If your running coolant in the system the boiling point will actually be LOWER !
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Average mix of coolant raises the boiling point by 10 degrees C,
    it also reduces the freezing point by about 40 degrees C.
    what lower temp thermostat fits and is recommmended for a 1g?
    Well in straight out terms anti-freeze will slightly raises the boiling point of water YES although glycol antifreeze additives will basically halve the heat transfer properties of say 100% water in the system.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
  1. RA65 22RE Bellhousing vs 1GGTE
    Last Post: 18-08-2006, 05:58 PM
  2. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 08:15 PM
  3. is now where am i, oil feed on 1ggte what am i, pipes on a 1ggte
    Last Post: 29-12-2005, 02:14 PM
