hey guys i read a quote that ra65 springs are the same as rt142. I have heard this is true what else in the suspension department would be excatly the same . shocks swaybars etc??/ thanks heaps
FJ20 Landcruiser alternator bolts to 3T GTE. Needs different plug and pulley.
just remebered - they 18R/18RG lower timing chain is exactly the same as a Holden 253/308 chain. These are available from every Tom, DIck or Robbo's spare parts store.
upper control arms of a celesior are not the same as the LS400
complete rear axle of a sprinter will bolt straight in a ke70/ ae71
thats funny...I thought celsiors and LS400's were IDENTICAL cars...Originally Posted by ke-70-ge
are you sure you dont mean there is a difference in the upper control arms for Airbag and Non-Airbag models?
that would be more likely but still unlikely...
Project Soarer II - Sold
Evo 5 - The silver fruitbox
I can confirm this, I have a T50 that was pulled out of an imported TE71 (2TGEU) and the spline will not match the TA22 driveshaft.Originally Posted by gearb0x
I'm surprised no ones mentioned this yet but:
18RG top timing chain tensioners can be use in 2TGs
TE71 Pitman Arms will fit a TA22 (just)
TE71 wiper motor fits a TA22 - has a few extra wires (intermitent ?)
Things that didn't work:
RA23 Tie rod sleeves don't fit TA22, in-fact nothing does and you can't buy them anymore. Whatever you do, be nice to your tie rods.
All aftermarket pitman arms (that I've tried to fit) for a TA22 are in fact for RA2X and will not fit (will hit your cross member).
Originally Posted by MR 1JZ
maybe youe right about non-airbag model
we had a celsior in our workshop and they were different.
found it very hard to find parts for a celsior.
Some more inter-model changes for you.
MZ10/11 rear stub axles and discs/calipers are interchangeable with MX73, therefore making an instant brake upgrade for the soarer as the MX73 rear discs are vented and the brake pads are about 20% larger. MX 73 rear pads will also fit into MZ20 brakes. Also early cressida (MX3*)idler arms can be replaced with T18 ones.
1JZ - 2JZ and 3SG
all share the same piston rings
When you refer to tie rod sleeves do you mean tie rod ends?Originally Posted by Invid
My mate in Malaysia did this, converted the 4AGZE into 20V-4AGTE
Block is still from the old 4AGZE and replaced the head with a 20SVT item.
Haven't read the whole thread, but RA60 rotors and calipers BOLT ON to an ST141... $35.00 for a set of calipers with pads and near-new slotted rotors from a wrecker... not a bad buy eh?
Ok I'm going to have to use my technical language:Originally Posted by YelloRolla
The adjustable bit that holds the two tie rod ends together. The bit you turn to change the wheen alignment...
Does that make sense?
Yes taht does make perfect sense. I guess that these shouldn't wear out!
I am also wondering if the tie rod ends (ball joint bit) and pitman arm may be the same as the KE20?
