Results 46 to 60 of 78
Thread: 20v starting then dieing
  1. #46
    T'ville, QLD
    Default Re: 20v starting then dieing
    any way to test if the ignitor is faulty?
    2T out 4A in....
  2. #47
    yep get another one or put it in a working 20v
    if u can get a 100kw ignitor a u have to break around and inside the 100 kw ignitor plug so it will plug into the 20v ignitor wiring plug it will work
  3. #48
    T'ville, QLD
    mmmk fixed the problem i forgot to put the earth lead back on the head but i like to think it needed new dizzy and shit anyway it was pretty worn
    ok now i have the same old issue it will start rev a little but then die if i keep a constant throttle it will run alright then hunt a bit then if i release it it will die again
    2T out 4A in....
  4. #49
    too low an idle? or those throttle stoppers previously mentioned?
    get a tacho reading on the lowest rpm before it dies.
    edit: dont worry skiddz .. its just like my backwards fuel pump ... i was ready to pull the injectors
    Black Betty >HERE!<
    (\__/)
  5. #50
    T'ville, QLD
    haha i at least stuck the inlet in a bucket of fuel and messed with wires till i had fuel squirting all over the garage
    ill play with the idle screws later on, but for now i have an assignment due monday and its ghey and i dont wanna do it
    2T out 4A in....
  6. #51
    i know the solution
    stiggz...care to embarrass yourself?
  7. #52
    dont touch the idle screws unlees u fukt with them earlier
    they are a pain tog et right even then u need a vacuum meter like they used to use on old weber carbies to tune
    just sell the car and buy something std
    then u wont get any headaches
  8. #53
    T'ville, QLD
    Quote Originally Posted by sideshow
    tell me dude wheres the fun in that
    me in my stupidity have put the iscv hose free to suck in air and not be meterd.... i shall get a bung/attachythingy for hoses tomorrow and stick that on the back of the airbox and hope to god it solves my problem.
    then i only have to sort out the exhaust leaks and the tractor like noise it makes, oh and stop the exhaust from hitting the diff see its fun!!!
    2T out 4A in....
  9. #54
    put it before airbox, post afm.
    you know im right...i was right about that hose wasnt i
  10. #55
    1. ditch crappy 4A poo spoontah motor
    2. Get 3SGTE godliness
    3. ???
    4. Profit!!!
  11. #56
    tractor noise?
    I think they're known to have somewhat noisy valve train, but I'm not sure its *that* bad, maybe I'm just used to it lol.
    What oil you running?
    I think I've noticed mine getting a tad quieter if I overfill the oil slightly
  12. #57
    T'ville, QLD
    tractor noise is due to hole in the exhaust
    mmmk guys it does the running then dieing thing still, now, if i wedge the afm open slightly she runs alright....so.... this leads me to beleive that a vac leak would do this..... is that the case? or am i completely wrong
    2T out 4A in....
  13. #58
    its that dodgy airbox of yours luke.
    needs more screws i tells ya
  14. #59
    T'ville, QLD
    hey guys
    thought i would mention that if i disconnect the AFM she idles very high at that but it looks to be better than with it connected, farked AFM?
    2T out 4A in....
  15. #60
    possible ... sounds quite good .... might not be farked ... just tampered.
    check the seal around the mixture / idle watsamabob on it
    Black Betty >HERE!<
    (\__/)
  1. Need help starting my 2TG!
    By sleeky in forum Tech and Conversions
    Last Post: 22-09-2006, 10:13 PM
  2. 4AGE Starting Problem
    By druu in forum Tech and Conversions
    Last Post: 18-09-2006, 08:23 PM
  3. Starting issue with 4age
    By trd-st162 in forum Tech and Conversions
    Last Post: 15-07-2006, 06:45 AM
  4. 20v problems starting
    By andy in forum Tech and Conversions
    Last Post: 28-03-2006, 04:41 PM
  5. 4AGE not starting correctly 5-10 times, then starting correctly?
    By phrostbyte in forum Tech and Conversions
    Last Post: 30-01-2006, 05:55 PM
