Results 1 to 5 of 5
Thread: Clutch fluid leaking
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Default Clutch fluid leaking
    Hey, i noticed my clutch fluid was going down a while ago (ever so slightly) and i know enough to know that it didn't dissapear so i had a look along the line and found that it was leaking from the gearbox, where the linkage goes in.
    Is there a gasket i can replace in there or something? from what i can see behind the boot there is an arm that goes right into the box. but i'd say the leak is comming from the hydraulic box deal behind the arm on the side of the box.
    anyone have any suggestions? will i have to replace this hydraulic bit?
    Thanks.
    Default Re: Clutch fluid leaking
    from your explanation which is a bit hazy...pics may be good. i am guessing that the seal in the clutch slave cylinder is getting a bit tired or has a bit of grit under it and the fluid is leaking past there.
    thats the last point that clutch fluid can leak from. anything after the slave cylinder is not a leak from the clutch system, unless its been sprayed over the clutch fork etc.
    you will want the clutch slave cylinder,....
    blake
    I like Stuff Backyard Mechanic mikie's Avatar
    or a clutch slave rebuild kit, mine cost $15 from repco on a sunday. easy to do but kinda messy. dont forget to bleed the system when ur done. u may also want to pump out the fluid that you currently have in the system to get rid of any gunk that may have built up.
    cheers mike.
    Jun 2006
    ahh, so that "hydraulic box thing" is the clutch slave cylinder?
    and i need a rebuild kit. awesome.
    thanks guys.
  1. aw11 clutch master cyl leaking (again)
    By adamaw11 in forum Tech and Conversions
    Last Post: 05-02-2007, 09:48 PM
  2. clutch pressure problem
    By spoolintanabe in forum Tech and Conversions
    Last Post: 06-12-2006, 12:23 PM
  3. Clutch fork problem
    By Spode in forum Tech and Conversions
    Last Post: 21-08-2006, 10:30 PM
  4. Clutch Fluid Line?
    By RO11LR in forum Tech and Conversions
    Last Post: 04-05-2006, 01:15 PM
  5. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 12:14 PM
