from your explanation which is a bit hazy...pics may be good. i am guessing that the seal in the clutch slave cylinder is getting a bit tired or has a bit of grit under it and the fluid is leaking past there.
thats the last point that clutch fluid can leak from. anything after the slave cylinder is not a leak from the clutch system, unless its been sprayed over the clutch fork etc.
