Results 16 to 21 of 21
Thread: 1j and 2j engine mount differences
    Default Re: 1j and 2j engine mount differences
    Ok, this is what I want to know. Will these semi solid engine mounts (GB for jza70 style) fit my car.
    RIght mount top
    Right mount bottom
    Left mount
    I have jzx81 mounts but I would be continuing to use the alloy part of it but replacing the rubber with this new stuff. It looks like the mounts may have been modded to bring the engine down lower in my bay. On the drivers side, from the bottom plate to top plate (which isn't joined which is why I need new mounts) is about 650mm. I couldn't get an accurate measurement on the passanger side.
    QUICKEST 1JZ'S IN OZ
    Junior Member 1st year Apprentice Mazman's Avatar
    im also interested to know if those semi solid mounts bolt up to a jza80!
    I remember seeing the jza80 mounts on a bit of an angle? if my memory serves me right! while these are just plain straight?
    IIRC from reading it on SF USA, the 96 onward JZA80 mounts (rubber sections) are interchangeable with the late style a70 crossmember. Those mounts on SF AU are designed for the later model crossmember so it *SHOULD* fit that 96+ JZA80.
    Do a quick search on SF USA for semisold mounts in the a70 section. They use the late model JZA8) rubber mounts as a semi-solid style upgrade.
    HTH
    Malicious
    JP: Did you get a chance to measure up the mounts on the weekend?
    spent most of the weekend cleaning the motor. subframe, steering etc and installing parts into the MX83. I'll get some measurments of the mounts tonight after work.
    All good, ta.
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 10:49 PM
  4. GE engine mount bracket
    By 1337_86 in forum Tech and Conversions
    Last Post: 14-11-2006, 07:45 PM
