Results 16 to 18 of 18
Thread: fitting an oil cooler to a non oil cooled 3tgte??
    Junior Member Domestic Engineer TA22 GT's Avatar
    Default Re: fitting an oil cooler to a non oil cooled 3tgte??
    My 3T GTE oil temp runs around 85 C when driving it without boost. Depending how much boost you run and how hard the engine is pushed oil temps obviously go up.
    For my engine at 14 psi boost the temp gets to around 105 C if I really give the engine a work out.
    Hope this helps,
    Simon
    I would like to be a Backyard Mechanic 3t-RA40's Avatar
    Quote Originally Posted by terryo
    the stock Toyota oil cooler take-offs are useless for performace engines and they also wont fix a stuffed engine. they are by-pass type only, meaning only a small part of the oil goes thru the cooler. i always fit a full flow sandwitch block that has a thermostat built-in. that way, they only allow oil to flow to the cooler when it has excceded a set temp. no point cooling cold oil as it just gets thicker and costs power. simple really. all parts in stock. www.roadandtrack.net,au
    terryo, what i was mainly trying to point out is that the toyota factory setup pictured also feeds oil to the turbo. Without something there, wheather there's an oil cooler in line or not, the turbo needs to recive oil from this location.
    Neil
    RA40 3t-gte. Haltech fitted.
    Power - 229hp at 17psi
    i have got the late model non oil cooled sandwich plate on there at the moment. i think i will get an oil temp guage today and post the results, that will give everyone a better idea if i need to do something or not. also 3t-ra40/ta22 gt have u ever had to buy a new starter motor for your 3tgte mine wont tick over anymore(as of yesterday) it has been playing up for a while, what vehicle did u specify to get another one?? if anyone knows what one will fit it would be appreciated. after seeing that 3t-ra40 and ta22 gt both have in excess of 200 hp i fell kind of sad with mine only having 84.
    thank you
  1. my SC14 fitting guide
    By Adsport in forum Tech and Conversions
    Last Post: 05-01-2011, 11:04 PM
  2. JZS147 Aristo Cooler Setup
    By Mos in forum Tech and Conversions
    Last Post: 20-02-2007, 10:00 AM
  3. Oil cooler questions
    By ONCE-NA in forum Tech and Conversions
    Last Post: 18-10-2006, 10:15 PM
  4. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
