Results 1 to 7 of 7
Thread: 4agze ignition issue...it has none!
    Forum Member 1st year Apprentice SLO-055's Avatar
    Tasmania
    Default 4agze ignition issue...it has none!
    hello!
    issue that needs guidance from those far more intelligent than me...
    4agze running an old group two motec ecu (ugh)
    eveyerthing seems peachy in terms of wiring it in, but no spark
    have pulse form distributor to ecu, and from the ecu to the igniter, but what sort of signal
    should i get from the igniter to the coil, cos i've got power to the coil, but no spark
    coil is ok, power to the injectors is ok, everything is fine, but it doesn't f*cken go!!!!
    any help would be greatly appreciated!
    insert witty post here, to allow people to see how funny and intelligent i am, and how much they would like to be like me.
    Default Re: 4agze ignition issue...it has none!
    what ignitor are you running
    just replace it anyway
    its pretty comon for ignitors to fail
    prob th emost common device that fail son cars
    for 100 bucks you can get a new one
    or goto wreckes u just need a 3 pin ignitor
    If most things have power could it be a bad earth to one of those parts.
    Is the igniter body earthed?
    Tasmania
    yeah, that much earth ol' man
    will try and replace the ignitor
    Tasmania
    does anyone know if there is a way to test if your ignitor is working??
    would be nice to be able to test it before going out to buy another one
    buggered if i'ev ever seen one before, i'll post up some photos, see if anyone has seen them before...
    how do u know that yr gettin pulse to ignitor
    if u can check this then you shoul dhave materials to check pulse to coil
    what ignitor do u have
    aftermarket or std 4agze
    you should get a pulse coming out from ignitor to coil aswell
    Tasmania
    yeh i was using multimeter, the bar on the bottom was reading a pulse, i just wasn't sure if that was the same as what the coil should be getting, but its all good now.
    thanks for the input everyone
    have a good one
    ed
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
  3. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  4. 4agze DLI on 20V
    By TauhuTauhu in forum Tech and Conversions
    Last Post: 04-04-2006, 05:39 PM
  5. Oil leak 4agze DLI type ignition
    By clean82 in forum Tech and Conversions
    Last Post: 30-03-2006, 09:46 PM
