Results 16 to 27 of 27
Thread: How do I make 7 Pack leaf springs?
    Default Re: How do I make 7 Pack leaf springs?
    You've hit the nail on the head, boxing it is what I meant, sorry for not making myself clear, I have trouble trying to type at the rate my brain ticks over sometimes
    1975 KE30 Two Door - 3K BP, K50, & BW4.3
    Rosewood
    only one way to find out....
    In say all this, you've got a KE30 by the look of it, the caltracs are a better alternative....
    Especially when it comes to suspension dynamics when the rear end is loaded up in comparison to slapper bars.
    yes true but I have had the slappers for some time now.
    If I bend them, i'll try the Caltracs
    do you even need slapper bars on a 4K'd rolla?
    i had an extra 2nd leaf (iirc, and maybe a main with eyes cut off?) and it never tramped... then again, it didn't grip so well either
    adding the front half of the leaf, as mentioned before, is better than making a slapper bar.
    even go so far as to add two extra main leaf front halves with the eyes cut off.... not going to tramp then (and if it does, your shocks are shit)
    actually.. what is the problem you are having? spring windup? or shocks not controlling bounce?
    I have trouble with axle tramp, before you say its the shocks I am using Monroe GT Gas.
    I want to fix this problem before doing my 3T conversion.
    I know slapper bars are not the ultimate solution, I should try adding leaves.
    Or then again maybe I should avoid doing standstills in the work car park.
    try using decent shocks first
    or perhaps modify your behaviour
    burnouts in work carpark.. why does that sound like a great idea?
    Would a rear swaybar help with the tramp?
    What sort of shocks do you recommend?
    no, rear swaybar is for body roll..
    i would recommend shocks matched to your springs
    get the spring rate sorted first, with a firm front half.. then get shocks to match.
    the K-Macs i had didn't cause tramp.. but i wouldnt recommend them.
    the tokicos didn't tramp either...
    koni? kyb? bilstein? take your pick... as bill said, you get what you pay for (except for bodgy yo dorifto brands)
    Thanks oldcorollas.
    I knew that swaybars are for body roll I was just curious, wheather it would help.
    Attachment 4187
    Is this what you mean ^^ ?
    no, completely different
    do you have any pics or know where I can find the correct set up?
    I am sorry but I am having a bit of trouble following you.
