Results 16 to 28 of 28
Thread: 1GGTE problem
    May 2006
    Default Re: 1GGTE problem
    yeah it wasnt the afm, i tried another.
    how do i reset the computer?
    with the afm off im assuming it would run better if you blocked with with your hand the same as with the afm on. it runs exactly the same either way.
    will have another look tomorrow or will take it back to the mechanic.
    May 2006
    oh and its running an safc btw, but that doesnt seem to make a difference whether its plugged in or not either :S
    so confused.
    Turboholic Grease Monkey VeeP's Avatar
    the suggestion here seems to be that the computer isnt recieving a AFM signal . . which it needs to know how much fuel to inject.
    u reset the computer by disconnecting power from the ECU for about 15min
    '88 Soarer GT-L
    '90 Supra Aerotop
    if you unplug safc u need to bridge the wires back together
    May 2006
    so if i got the safc tuned would that fix the afm problem?
    is it because the battery + safc have been disconnected and its lost its memory and therefore not operating the afm?
    but still shouldn't the car just stall will no safc?
    thanks for all the help, im confused lol
    ok holdup
    first,, is the SAFC correctly connected? do u need wiring instructions to confirm this?
    if ur SAFC is wrongly connected u might not be getting an airflow signal to the ECU which is what would be causing the problem
    '88 Soarer GT-L
    '90 Supra Aerotop
    i would first get it running good without the safc
    then get it tuned otherwise you could bring another problem into the tuning
    Jan 2007
    western australia
    i had the exact same problem on my GA70 supra. Turned out it was my dodgy SAFC wiring.
    May 2006
    dayzii: how did you fix it? did you just fix the wiring or did you take the safc out?
    emd-tx3
    u might wanna pull out the SAFC and try again. . make sure all the wires goin to the AFM are connected properly because if just one wire (airflow) has a bad connection it will cause problems.
    once u get it fixed and running without the SAFC u can chuck it back in.
    otherwise if u dont wanna rip out the safc ull just have to follow alot of the wires to make sure they're all good
    '88 Soarer GT-L
    '90 Supra Aerotop
    Jan 2007
    western australia
    some of the wires just needed to be resolded. I kinda did a shit job the first time
    May 2006
    ok safc is out and its running and driving and all that.
    problem now is is seems to splutter a tiny bit at high revs on boost, like doesnt know if it wants to boost or not. its mostly in 1st and a little in 2nd, 3rd seems fine.
    any ideas?
    May 2006
    also the LSD doesn't seem to be doing its job, even in the wet it seems both wheels aren't spinning.
    it worked before the swap, any idea's why it would have stopped now or how to fix it?
  1. 1GGTE problem help!
    By Regan in forum Tech and Conversions
    Last Post: 22-02-2007, 01:58 PM
  2. 1GGTE 12 pound boost problem ? i need some help !
    Last Post: 29-12-2005, 08:12 PM
  3. 1ggte Engine Problem
    By ToNkA in forum Tech and Conversions
    Last Post: 26-12-2005, 09:27 AM
