Results 16 to 29 of 29
Thread: ke70 overheating problem!!!
    Default Re: ke70 overheating problem!!!
    even the lil one that you didnt know was there....
    it only takes 1 split in a vacuum hose for it not to run....
    i found out my bearings have gone
    so gotta replace all this crap on top end
    sorry guys it wasnt the bearing it was the valves
    so gonna cost me like 1g to fix
    wat a bitch
    ill sell you a 4k....
    or just a 4k head....
    i think buying new motor would be much cheaper
    including postage lol
    postage on a head is bugger all really
    yeh tru but then again i dont kno if anythin will happen to the new head
    soi mite aswell get this done and i kno nothin shouldnt go wrong with it
    you could save yourself $800 though....
    Quote Originally Posted by GU11TY
    the previous owner used some white inhibiter stuff in the radiater and wen we put water in the radiater and turned the car on it went white!
    that wouldn't be "emulsified oil from blown headgasket inhibitor" would it?
    wat a bitch
    thats completely stupid.
    reco is like $120.
    new stems, guides, valves and seats should still be less than 1K..
    nice "friend"
    don't spend 1K on the head.
    find out what is wrong with head, and what caused it. they are very hardy engines, so to have something go that badly wrong, something is fucked.
    get second hand head, get it recod for $120ish (sydney brake and clutch in alexandria ) and then do compression test, then fix what is wrong....
    less spending, less typing, more thinking.
    edit: to put it bluntly.. the motor is probably rooted. how did you not see the lack of coolant before you bought it?
    don't skimp on checking the motor out properly and thoroughly. don't depend on the "mate" mechanic. check the compression, check for leaks, with the car running, check the radiator for leaks..
    oh, that white stuff could well be Chemiweld
    i was gonna get the original head machined etc and get new valves etc
    i think i got told the machining alone was gonna be about 500 then labour and parts etc at most should be 1g at most
    probs less
    skim head $ 40
    reseat valves and valve seats $80 (if valves are farked, second hand replacements would be shit all)
    how much more machine work can you do to a 4k head unless performance is in mind?
    maybe the head is corroded and thats whats gonna take the money or something? sounds like your getting stooged to me
    yeh ill get the prices if i can and se wat u guys think
    good thinking batman
    probs less
    but... why?
    you can probably get second hand head for free (or put a 3K head on for free increase in compression ) and then spend $150 on reco and new seals.. and thats it.....
    thats abotu all it is worth also
    if i were you, i'd pull the block out at same time and check bearings and pistons...
    if you need new valves.. the rest is probably worse
    aght ill talk to the dude n c wat he says
    thanx 4 the info
  1. 4a-c Ae82 Overheating Problem!!!
    By nos4ag in forum Tech and Conversions
    Last Post: 07-11-2008, 08:27 PM
  2. KE70 indicator problem
    By sprinter_adam in forum Tech and Conversions
    Last Post: 05-09-2006, 04:27 PM
  3. Overheating problem on 3sgte,need help PICS
    By Aust162 in forum Tech and Conversions
    Last Post: 05-07-2006, 07:07 PM
