Results 31 to 45 of 46
Thread: Suprise 4A failure.
    Default Re: Suprise 4A failure.
    Quote Originally Posted by Joshstix
    Interesting. I have only really seen FWD ones, GE and GZE and they have all had rubber in them.
    I'll check it tonight and confirm it's the case, it could well be that the rubber layer was quite thin and not as visible as the ZE pulley it replaced. I have been known to be wrong
    My KE25 thread
    dose? depends i guess on where the bov was positioned and where the throttle body is in relation to it (before or after).
    Not too familiar with the GZE setups but maybe because the clutch disengages between shifts? not like a turbo where pressure is constant. ???
    Black Betty >HERE!<
    (\__/)
    Junior Member
    Auckland
    If the bov is after the throttle body you will get very little noise, if any. You wouldn't even need a bov on the standard setup.
    Also the clutch doesn't disengage between shifts, when you back off the gas the clutch stays ingaged for 5 seconds, so it doesn't switch on and off all the time around corners, gear changes and what not.
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    It's cried ENOUGH, time to do a new one, better, stronger, faster!
    First I've seen a snapped crank from the nose, early mx5s were known for such dramas.
    I guess a for sale ad in in order:
    4agze not running
    made good power when in car
    only driven by my grandpa, NEVER off the limiter under the bridge sideways at calder
    needs new crank
    Dan
    Quote Originally Posted by MRMOPARMAN
    i reckon the best way to fix this problem would be to turbo that sucker
    Rubbish! Glue it back together with a bit of Araldite and you'll be ready to go within 48hrs!
    seeyuzz
    river
    Quote Originally Posted by river
    Rubbish! Glue it back together with a bit of DevCon and you'll be ready to go within 48hrs!
    fixed ... plus would be great to see this stuff used for all kinds of other stuff that it's not designed for
    its a common problem with the old 90's 1.5 carby lancers....they tend to do it....round the 150k mark......then its time for a new motor.....
    blake
  8. #38
    Pfft, but that's just a lancer.. What's a new motor worth in one of those? 25 to 30 cents?
    Facebook | LinkedIn
  9. #39
    Junior Member Backyard Mechanic bathurst-91's Avatar
    Quote Originally Posted by 4agte
    i vote keyway failure
    perhaps.. but either thats correct and im in for some hassle or it isnt. I had a wobbly crank pulley on my gze (non s/c though. gze block running turbo) for too long a period! inexperience meant i didnt know what it was. until it was taken off and found that the pulleys keyway slot had cracked and running around (including drift days) with this wobbly pulley had manged the keyway... i got it filed a little bit and managed to get a new key fitting 'snug' in there. whacked on a ge pulley and its been running sweet since.
    i'd say the effect of the s/c + pulley at angle?
    -Andrew
    A race continues forever...
  10. #40
    Junior Member Grease Monkey Schmitt's Avatar
    Pretty sure my stock RWD bigport pulley is solid, my old ZE pulley was rubber damped. I'll check the pulley tonight to confirm.
    FWIW my stock RWD pulley is also solid.
    Ben
    Founding member of SPOOT RACING
    Schmitts 4AGE TA22
  11. #41
    Quote Originally Posted by Schmitt
    Ben
    Not all of them are like that - For example my RWD had a thin rubber ring (that I didn't know it had) and I had a lot of trouble getting it to run properly when it got the Motec.
    It's a long story, but the outer ring, where the fanbelt runs on, had come loose on the inner pulley and backed itself off a good 30deg.
    So I was trying to time the engine with it a good 30deg retarded ....
    The old screwdriver down the plug hole trick to get a rough TDC and the timing mark was waaay out.
    So anyway, the point is to be careful, it may well have a rubber insert that you can't see, and it may well be out of alignment.
    www.billzilla.org
    Toymods founding member #3
  12. #42
    maybe it is time to use these..
  13. #43
    Junior Member Grease Monkey crostek's Avatar
    I have broken a Mazda engine at the same part of the crank, the blower belt was not over tensioned (spring load auto tensioner), the water pump was run off the cam belt and the only other A/C belt was for the alternator, the only thing I could put it down to was the crank nut was over tightened when I put on the custom pulley (I didn’t use a torque wrench) or the pulley I made was not machined right?
    Motor ran for 6 month before it failed.
    Hope you get on the road again soon.
    I would be VERY careful turning the crank without the cams turning you mite bend a Valve, if it has not all ready when it snapped?
    My motor did.
  14. #44
    ^^ gze is non interference iirc
  15. #45
    wa
    howley shiat !
    top work
    My Corolla ! - 4AGTE
    KP61 - 4AGE
  1. Ignition system failure, trying to find fault...
    By mike1980ra40 in forum Tech and Conversions
    Last Post: 31-01-2007, 08:29 AM
  2. Theories on Clutch Failure: Weird case
    Last Post: 08-10-2006, 10:41 PM
  3. Echo Keyless Entry/Security failure
    By anthonyhfoote in forum Tech and Conversions
    Last Post: 20-09-2006, 10:47 PM
