Results 16 to 27 of 27
Thread: remote brake booster?
    Perth, WA
    Default Re: remote brake booster?
    ok just got the measurements. from pedal pivot to the pedal is 12", from pedal pivot to the fork hole is 2", which mean i have a 6:1 ratio pedal. but it just don't apply enough force to the calipers. did i missed out something?
    Dec 2009
    Kwazulu Natal
    I'm planning a remote booster stup on my 1400 aswell.
    Moving the existing master and booster and mounting it under the bin at the back.
    Was thinking of using a Clutch master on the brake pedal pushing a clutch slave of similar diameter on the brake booster.
    Then the brake booster will push the brake master as usual but from another place.
    So it will be a Clutch master on the brake pedal.
    Then a clutch slave on the pedal side of the booster.
    Using a clutch master and slave of similar diameter will give me a 1:1 ratio from pedal to remote booster.
    Would that work fine ??
    Thanks
    Dec 2009
    Try doing a search on the physics of hydraulics
    if my memory sereves me correctly
    to over come your braking issues you need to reduce the diameter of your master cylinder
    it has been a long time since I did the research ( pre internet) but I am prety sure that is the theory
    regards
    shorne
    Remote booster is an easy way to go PBR here do them or at least used to as many an early holden and even my first corolla had one. Basically you can mount it anywhere..
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    You guys with remote boosters... any photos of your setups?
    Sounds like a possible option for my UZA28 so i can move the engine back that bit further.
    Hoppers Crossing
    hi
    i'm doing this for my XP Falcon as it has very very VERY deadly brakes.
    some interesting info here if it helps http://www.stormloader.com/falconccwa/brakehint.htm
    Oct 2012
    Dragging up this old thread. There doesn't seem to be anything dedicated to remote boosters, just lots of questions and answers spread about the place. Good topic for a technical or "how-to" FAQ, by someone who knows brakes well?
    I came across this unit while looking for a dual circuit booster, anybody used one?
    They're available here, and many other places too no doubt.
    Cheers.
    Traditionalist Domestic Engineer parrot's Avatar
    This guy clearly runs a business rebuilding them. Have been thinking about one myself
    eBay My World - 1947dgb
    Cam mountain I feel different from the ordinary
    or go booster-less with the right sized master cylinders for front and rear, with a floor mounted pedal box etc.
    Oct 2012
    I've considered installing two master cylinders with a balance adjuster. I'll probably need them, 4 pot AP copies going on the front and MGF upright, axle, etc for the rear, initially at least, the MGF caliper is a heavy iron beast and I've got some Nissan alloy calipers to fit later, just need to get a handbrake working with them. It just worries me a little that I'll end up going through a number of, smaller and smaller, master cylinders until I get the right feel and pedal travel. Might be a collection worth framing .
    What's the advantage of a floor mounted pedal box?
    Cheers.
    floor mounted box witht he master cylinders on it takes the master cylinder out of a cluttered engine bay.
    basically easiest way of going twin masters with a balance bar is with a premade unit, if you are sourcing this through a good performance shop they should be able to give you a calculations sheet that will help you size your master cylinder to suit the caliper. I know my brake guru showed me one, but I ended up using his calipers not what I had.
    Cheers, Andy
    Oct 2012
    Got it! Thanks Andy.
    Cheers.
    By The Witzl in forum FAQ
  2. AE86 Brake booster question
    By Akury in forum Tech and Conversions
    Last Post: 21-02-2007, 06:48 PM
  3. brake booster selection
    By STR8 2.8 in forum Tech and Conversions
    Last Post: 27-09-2006, 06:48 PM
  4. Removing brake booster, for race?
    By Jonny Rochester in forum Tech and Conversions
    Last Post: 10-01-2006, 09:26 PM
  5. 20V Brake Booster Vacuum Problems
    By ShiRi in forum Tech and Conversions
    Last Post: 15-12-2005, 07:06 PM
