Not quite sure what that is frankly.
A/C idle up VSV looks like this one on the left. This one actually came from an Aust delivered AE82 twin cam, however I believe they are the same.
The one on the right is the general idle up VSV.
Is this the AC idle up valve for a JDM 4AGE? (This one's on my son's AE86 with fwd 4age).
If so, where can I get one? What car does it come from?
I still have the ac switch that was in my ae86 with the 4ac, so that should be OK for the electrics.
Don't force it... use a larger hammer.
If it breaks, it needed replacing anyway.
Henk
Yes that will do the trick but it is vac operated so you need another vsv like the one on the right in the pic above to triger it.
MATT.
OH my mistake just had another look at pic and you would need a 3 outlet vsv or the diaphram on the valve will not return.
You should be able to pick one up at your local wreckers for about $10.00
Or if you are near Kilsyth I may be able to give you one
MATT.
P.S. can be from Corolla,camry,supra, whatever they are all simillar.
Thanks guys... I'm in Ballarat, so I'll try my luck with the local wreckers first.
Henk
