Results 1 to 1 of 1
Thread: Diff Ratio Good Link
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Default Diff Ratio Good Link
    This is a link to a large forum about BMW final drive ratios and the rationale which should resolve many of the issues rasied about what diff to use in what four cylinder and six, as BMW have a huge fleet of different cars.
    And different engines.
    http://member.rivernet.com.au/btaylo...ferential.html
    SOme interesting discussions such as this reprint about how to test your ratio in the car easily..............................
    Number of Teeth on Ring Gear
    Rear End Ratio = -------------------------------
    Number of Teeth on Pinion Gear
    It is usually inconvenient to count the teeth. Luckily rotating
    the wheel and counting driveshaft revolutions works just a well.
    The ring gear is bolted to the differential housing. The rotation
    of the differential housing is directly related to the rotation of
    the rear wheels.
    If the rear wheels are both rotating at the same rate, they match
    the differential housing rotational speed. If one wheel is held
    stationary, the other wheel rotates at twice the differential housing
    speed. The moving wheel rotates at double speed because of its
    own motion plus the extra forward motion from the differential
    spider gear rotating along the stationary gear of the fixed wheel.
    Left wheel + Right wheel Rotations
    Diff Housing Rotations = ----------------------------------
    2
    So if one wheel is held still, it takes two rotations of the other
    wheel to equal one rotation of the diff housing (and ring
    gear).
    Drive Shaft Rotations
    Open Diff Rear End Ratio = 2 x ----------------------
    Rear Wheel Rotations
    From the example given (one wheel held still):
    48 driveshaft turns for 25 wheel turns
    48
    Open Diff Rear End Ratio = 2 x ------- = 3.84
    25
    For limited slip differentials, both wheels move together when
    they are off the ground because of the preload on the clutch
    pack. This preload break-away torque should be about 45 ft-lbs.
    (Of course, if you hold one wheel, the limited slip acts just like the open differential
    - -- it's just much harder to turn the free wheel).
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
  1. Diff noise
    Last Post: 11-05-2006, 10:14 AM
  2. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 20-04-2006, 12:25 AM
