Results 1 to 7 of 7
Thread: 3vz-fe headgasket
    VAASA / FINLAND
    Default 3vz-fe headgasket
    what kind headgasket 3vz-fe camry engine have, in stock , steel or organic ?
    and how much engine torgue stock head gasket can hold , ?
    thanks : juha-matti
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    VZ engine series FTW! Grease Monkey Timma's Avatar
    May 2006
    Default Re: 3vz-fe headgasket
    http://www.toymods.net/forums/showthread.php?t=18875
    Here is someone who is building up there 3vzfe for a mr2, i'd suggest pm'ing him for the details of the build. Also search button is your friend
    I'd also give this a read...
    http://en.wikipedia.org/wiki/Toyota_VZ_engine
    vzv21 camry 2vzfe v6 - aka mr burble or white one
    VAASA / FINLAND
    THANKS , wikipedia i have read before , hmm i know now without asking , i can see it in pictures
    - IQ 1.0 -09
    - Lexus IS250 -06
    Alabama
    Cool Re: 3vz-fe headgasket
    They're pressed gaskets. Paper cored. No MLS gaskets for a 3vz-fe is avalible, tho you can use custom copper, or custom MLS.
    If not, find some ghraphite gaskets. In the USA we have Victor's.
    Behind those... Would be OEM Toyota gaskets.
    I've had good success with the victors.
    VAASA / FINLAND
    anyone try to fit 1mzfe gasket, are they possible to use with work or without extra work ? atleast some of them or all use MLS type gaskets.. again, another project..
    - IQ 1.0 -09
    - Lexus IS250 -06
    May 2006
    Looks like the oil drain and coolant galleries are different but only slightly. The bore is 78mm on the 3vzfe and the 1mzfe is 87.5mm, I very much doubt it will work.
    VAASA / FINLAND
    Thanks, i though it maybe like that, dEsign is so near. Maybe had to comPare with block and head.
    - IQ 1.0 -09
    - Lexus IS250 -06
  1. 7MGTE Headgasket Problems
    By Mundoolun in forum Tech and Conversions
    Last Post: 28-11-2006, 08:56 PM
  2. 3T-GTE MLS Headgasket!
    By setsuna in forum Tech and Conversions
    Last Post: 15-11-2006, 06:38 PM
  3. 5SFE Headgasket
    By Ghetto-AW11 in forum Tech and Conversions
    Last Post: 04-05-2006, 11:13 PM
  4. 3s-ge with 3s-GTE headgasket
    Last Post: 02-04-2006, 04:14 PM
  5. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 03:40 PM
