Results 1 to 3 of 3
Thread: 3s-ge with 3s-GTE headgasket
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    Default 3s-ge with 3s-GTE headgasket
    hi peoples. i tried to do a bit of searching (google and old forums) but could find what i'm after
    just a question. can a gen1, 3s-ge take a 3S-GTE headgasket. i think the 3s-ge headgasket is about 1 - 1.2mm thick but not sure on the thickness of a 3s-gte head gasket.
    would there be much of a differnce in running the GTE one?
    i'm just about to replace my headgasket and was just curious if i should go the stock one or go with the GTE one (witch i can prob get cheap)
    thanks fella's
    Rosewood
    Default Re: 3s-ge with 3s-GTE headgasket
    Unfortionately no, not as simple as that. The thicker headgasket will drop your cylinder compressiona bit too much.
    The EPC has the headgaskets for the 3sge and 3sgte as different (although it is for the gen2, id imagine it would be the same for the gen1).
    Melbourne Victoria
    i have .8 of mm in steel h gaskets to suit 3sge 120 plus posatge this will raise you comp
  1. 5S FE to 3S GE
    By adam golder in forum Tech and Conversions
    Last Post: 05-10-2007, 09:47 PM
  2. 2S -> 3S Conversion
    By 81rolla in forum Tech and Conversions
    Last Post: 22-02-2006, 01:08 PM
  3. oils an't oils what to use in a 3s gte?????
    By sirbabblealot in forum Tech and Conversions
    Last Post: 14-02-2006, 09:26 PM
  4. 3s rwd conversion parts, what else needed?
    By CoronaC in forum Tech and Conversions
    Last Post: 11-01-2006, 07:43 AM
  5. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 03:40 PM
